Looking at bigger cams
Old May 21, 2008 | 03:38 PM
MachoCamacho's Avatar
Default Looking at bigger cams
This coming winter I'd like to get heads/cam for my car. I've already got the heads picked out to be Dart 225's, but the last time I looked at cams was when the MS3 was pretty popular. I've been considering the MS4 or TSP 233/239 112 but wondering what other people suggest. Choppy idle isn't a bad thing for me. It is not daily driver and I'd like something aggressive.
Old May 21, 2008 | 03:40 PM
Almostryan3's Avatar
Trex.
Old May 21, 2008 | 03:42 PM
I'd like not to have to notch the pistons as well though.
Old May 21, 2008 | 03:47 PM
MS4 I think you may have to but I could be wrong.
Old May 21, 2008 | 07:34 PM
TheLS1Kid's Avatar
Bigger is not always better.
Generally the bigger the cam, the higher you have to spin the motor to make power. In other words it will be slow as **** in the lower rpms.
Is this a street car or a track car?
Old May 21, 2008 | 07:42 PM
TXZ28LS1's Avatar
bigger is definitely not better!! honestly the biggest i would go is the 233/239 cam. but other cams i considered are the 231/237 or TR 230/236 cam.
Old May 21, 2008 | 07:43 PM
INMY01TA's Avatar
I've always been a fan of the TSP 233/239.
Old May 21, 2008 | 08:41 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm pretty sure the smallest valves available stock from Dart 225 heads are 2.02 and 1.60s. With a cam as large as a MS4 or most things close to that you're going to have to flycut.
Old May 21, 2008 | 09:22 PM
HEMIETR's Avatar
Not necessarily true. Nothing a little gearing can't change. I have had four different cams from 224 up to 244/250 which I have now. With the right combo a bigger cam can be completely fine. You can't throw a big cam in an otherwise stock car without issues.
Old May 21, 2008 | 09:40 PM
orange1999ws6's Avatar
From: rochester ny/ cannon air force base, new mexico
i run the "hellion cam" which is a 244/248 630/630 at 112 and its pretty big driveability at low rpms are not go good but screams at high rpms, im going in for patriot ls6 stage 2 heads in a few weeks but this cam is a custom grind from neweraperformanceparts.com check it out
Old May 21, 2008 | 11:20 PM
TheLS1Kid's Avatar
I definitely agree. Rear axle gearing would help greatly.
I was just giving and example with stock gearing in mind.
