help ls1
Old May 25, 2008 | 11:07 AM
superLS1camaro's Avatar
Default help ls1
i have a 99 ls1 camaro. when i got the car i put a ls6 intake,561 lift cam,long tube headers.with a tune the car made 360 and 343ft at the wheels and with a 150 shot it made 520 and 600 ft at the wheels.i had a rod bearing go out.so i am rebuilding it.i am going too put new rods bearings,arp rod bolts and head bolts.i am thinking about getting the head ported and deck 30 thouands. i want the car too make over 400 at the wheels on the motor.should it make 400 ? or should i go with a bigger cam? give me some ideas thanks
Old May 25, 2008 | 11:15 AM
jsteele90's Avatar
need more info than that about your cam
Old May 25, 2008 | 09:06 PM
561 lift 224/228
Old May 25, 2008 | 09:13 PM
chuckyt1's Avatar
Look into some PRC/Patriot/Livernois stage 1 heads. Won't cost you much more than having your stockers ported and milled. I'd think you could do 400 with that cam. I have the PRC LS6 heads and could not be happier... Maybe search for your cam in the dyno section and see what guy's are getting out of it.
Old May 26, 2008 | 08:44 PM
thanks for the tip
