cam only 400whp
Shift point on both are about 66-6700rpms.
Idle clip
http://www.youtube.com/watch?v=A2dDvDgXDMo
4.10's are ideal for the M6 so everybody says ( I don't have them) but I have seen a high rate of failure in the 10 bolt with 4.10's. The pinion is really small to get that ratio thus making it weak. I'm going with 3.73's and when I get a aftermarket rear end I will probably run 4.10's or 4.30's. If your not going to do any drag racing I would say 4.10's if you are I would say stick with what you got or run 3.73's.
FYI 230/232 110+2 = 397 whp and 377 trq.
Edit I think my thread with the dyno sheet got deleted or something I can't find it anymore.
I will post up a link to the thread with my dyno sheet in case you want to look at it.
Chris1313 has a 230/230 111+2 and he made 422 whp through an auto. Its hard to shoot for a # because you really don't know what your going to get. I would stay low 230's nice mix of street manners and power.
Also as to the OP, take rocks advice and have Pat G or Preditor spec you a cam to work best with your current combo
That FMS cam would probably work. I went back and forth on cams so many times I figured I would let somebody else decide for me. Told Pat. what I had and what I wanted and he hooked it up.
You want to fix something that ain't broke? I don't think so.
Oh so you have to buy a new rear end so you can get to work? Ok.
https://ls1tech.com/forums/member.php?u=210
You can see in his sig where to click for his cam website.
Good luck.
idle http://www.youtube.com/watch?v=TKo_kVT92u8
i can learn alot from u
