Engine Builders - Listen-up
Old Aug 13, 2003 | 06:07 PM
DailyDrivenls1's Avatar
Default Re: Engine Builders - Listen-up
Some of you are taking about iron heads. I wasn't aware that these were offered on genIII motors. What did they come on?
Old Aug 13, 2003 | 06:25 PM
rodent's Avatar
Stealth- I have a set of cast iron 6.0 heads that I'd let go REALLY cheap if you go that route.
I also have some special head studs that Formulation sold here back in Feb 03.
Date: Feb 12, 03
Custom H-11 Head Stud Kits Available
These are ready to go, about 6 sets have already gone out and I have about 14 sets left. These are custom made Head Studs in kit form made out of H-11 material rated at 265,000 psi T/S, for reference stock is 107,000 psi T/S(weak!) and the ARP head studs are about 190,000 psi T/S. H-11 is far superior to the ARP 8740 Chrome Moly material, in every aspect. These will work very well on boosted apps to prevent head lifting and give more clamping force. The company that is making these also makes all of Katech's C5R head studs(275,000 psi T/S) that run $1,000 a set and many many top racing teams fastener's. They use H-11 material for most Top Fuel apps and extreme power setup's and it performs great. They work with this material alot, have tested it extensively and have a special heat treat procedure for it to optimize it's performance. They come black oxide coated for corrosion resistance and are supplied with the best lube on the market. These are the best studs for the money spent at $375 shipped, e-mail me at indacalinc@attbi.com (might be changed to indacalinc@comcast.net ) if you want a set or more info, Thanks Dave
Maybe you can email him and see if he still has a set. Besides that, I think you'll need to go to a larger dia. head stud.
I never liked using copper. I had nothing but problems when I used copper on my BBC.
Old Aug 13, 2003 | 08:05 PM
OSR 1's Avatar
1300 rwtq
why dont you back it down a little and go to the track and see how it runs
Old Aug 13, 2003 | 08:14 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Ken, what is the best mph on for the ESP shop car, 152mph?
Old Aug 13, 2003 | 09:01 PM
OSR 1's Avatar
8.93 at 153 at 3205LBs
making 835hp torque of 850rmtq I think
Old Aug 13, 2003 | 09:25 PM
stealth's Avatar
We spent the day working with ARE, ARP and SCE, and have decided to O-ring the block, change to a head bolt we can torque to 140 lbs. and change from a 200-500 wet shot to a 100/200 dry shot. At least we can race the car while we investigate head fasteners, iron heads, etc. I appreciate the help and many suggestions from the LS1 tech crowd. We proved we can make huge numbers but reliability suffered.
Old Aug 13, 2003 | 11:14 PM
dano32773's Avatar
This is just a suggestion but you might try activating the nitrous at a higher rpm. Activating it below 3000 seems kind of crazy to me. What ever hp increase you are looking for from the Nitrous (Lets just say 300 hp for an example) will be the increase you will get over base power at all rpms where the nitrous is engaged.
That much hp increase at a low rpm would be an incredible cylinder pressure increase.
(300hp x 5252)/2800rpm = 562 extra ft/lbs of torque. That is pretty insane and a good reason for avoiding spraying at that type or rpm.
Thats the beauty (sort of) of nitrous. Want to make more torque just keep spraying it at lower and lower rpms. Torque just keeps skyrocketing. Those ls1's just werent designed to put up with those types of cylinder pressures.
Old Aug 13, 2003 | 11:17 PM
dano32773's Avatar
oh yeah and if you really want to have something to brag about then make some real power naturally aspirated. Anybody can build an engine that will print big numbers with a big shot of spray, but it takes a real builder to make big NA numbers.
Old Aug 14, 2003 | 01:42 AM
rodent's Avatar
Go tell ARE and Lingenfelter that...
I want the power of FI but have it streetable. Here in Denver, its hard enough to get the NA cars to run that great. Supra's eat most LS1's up here which is why I'm going turbo. Its all about how much power and how fast you really want to run. Different strokes for different folks.
Old Aug 14, 2003 | 02:11 AM
z0sense's Avatar
If that were the case this thread wouldn't exist. I have never seen an NA LS1 have a problem lifting the heads. Anyone can make big numbers with an ls1 NA (depending on what is "big" to you)......but to make any kind of "real power" you have to have a power adder. And to run any kind of power adder is way more in depth then any NA motor....sorry charlie.
BTW,
I am basically saying your comment does not apply to ls1/6's above 550+ RWHP. That seems like something somebody from the "old school" would say. You will never see a 1000+ HP NA LS1........sorry. The greatest couldn't do it!
Old Aug 14, 2003 | 07:37 AM
PacerX's Avatar
My project might have just died, and have to be scaled back to lower hp levels. Shoulda started with a SBC.
"OVER? Nothing's over til we SAY it's over! Was it over when the Germans bombed Pearl Harbor?"
"Germans?"
"Let him go... he's on a roll."
At 1300hp, the ~20hp you might give up for an iron head and heat is irrelevant. People have been making iron heads and nitrous work for years.
Rob Raymer had the same problem. He (as far as I know) never really solved it because he was unwilling to switch to an iron head or get radical with the fasteners.
Where's the car and the engine? If you want to get serious, truly serious, about the aluminum heads then we can engineer a truss system (like a girdle) to stiffen the heads - but we could use a custom valve cover to do it.
It's not going to be like any valve cover you've ever seen (I'm thinking billet stainless), but I think it can be made to work. The trick now is to deepen the head section and use steel at the extremities.
I'll give you the engineering consulting for free, just to see an LS1 lay down 1000hp.
Old Aug 14, 2003 | 08:31 AM
  #32
stealth's Avatar
Pacerx, we are certainly willing to work with you on a girdle design. I'm going to Super Chevy this weekend and will ask the SBC guys about their various designs.
My project is not over, we're just going to backup, make some mods and move forward more cautiously. The first priority is to get the heads to stay down using only the blower, then we'll add small dry shots. Hell, the car has a valid license plate, smog sticker and mufflers, and makes a mean street machine!
BTW, we have also installed the TSI engine management system, that piggy-backs on the GM PCM, and are communicating with GMHTP magazine about an article on TSI and the car.
Old Aug 14, 2003 | 09:56 AM
  #33
LS1Tech Co-Founder
Keep us posted.
If I can't keep the heads on my car I will investigate going to iron heads, but I only want to make around 800 crank hp this year.
Old Aug 14, 2003 | 10:00 AM
  #34
stealth's Avatar
PSJ,
Is anyone at this site using p/p, LQ4 iron heads on an LS1? Other than the substantial additional machining, I can't think of a good reason not to try them in our situations.
BTW, we might drill/tap the heads and install 9/16" studs.
Old Aug 14, 2003 | 10:06 AM
  #35
CHRISPY's Avatar
That is possibly the silliest thing I have read on this forum LOL!!
Old Aug 14, 2003 | 12:02 PM
  #36
stealth's Avatar
Chris ARE 360
I agree with your comment. While you can obtain worthwhile info at this site, you also must put-up with the inevitable and worthless.
Old Aug 14, 2003 | 12:10 PM
  #37
LS1Tech Co-Founder
I cannot think if anyone offhand running iron heads.
What do you think of Dave White's custom head studs?
Old Aug 14, 2003 | 02:07 PM
  #38
dano32773's Avatar
BTW,
I dont know about that. We have made over 600 hp at the wheels NA. And no you will probably never see a 1000 hp NA LS1 unless there are some better blocks designed in the future and you develop a c5r head design that will flow around 450 cfm. If its so easy to make big numbers with an NA ls1 then why dont more people do it? Everyone knows that there is way more of a challenge in making an all motor combo work and win races than there is in making a power adder engine make power. Look how easy it is for the mustang guys to make 1700+ hp with turbos. Thats why not near as many people build NA cars these days. It is just too challenging for your average builder.
Old Aug 14, 2003 | 02:18 PM
  #39
dano32773's Avatar
So let me get this straight. You dont think it is easy to make big power with a power adder, but you do think that anyone can build 700 hp non c5r headed engines?
THAT is the silliest thing I have ever read.
So I guess that Warren Johnson, and Greg Anderson are just chumps and any of these power adder engine builders could just dominate Pro-Stock racing if they wanted to but that it wouldnt be as much of a challenge as building turbo, or nitrous engines?
Or maybe Winston Cup engine builders are just hillbillys compared to the power adder guys too. You are probably right I think I will start building WC engines because it is so easy to make power NA.
Oh wait a minute this is the real world where the most competitive forms of Drag racing and Stock car racing in the country have to use NA engines.
Old Aug 14, 2003 | 02:31 PM
  #40
CHRISPY's Avatar
No what I am saying is that it is MUCH MUCH harder to get a motor like the LS1 to stay together at RWHP levels above 800 without lifting heads, distorting the block or having the whole thing come apart. ARE has several cars in the 9's all motor with one car doing it with only 382 cubic inches and relatively budget heads. (2.02/1.57 valves)
