Arp
Old Jun 4, 2008 | 06:37 AM
JDC's Avatar
JDC
Default Arp
Are the ARP head bolts reusable
Old Jun 4, 2008 | 06:59 AM
aNuBiS's Avatar
Most definitely
Old Jun 4, 2008 | 12:21 PM
zman1969's Avatar
Default Arp
I bought used ARPs for this reason too so what is the torque procedure when thay arent TTY bolts? not to hijack but i feel its a good related question
Old Jun 4, 2008 | 12:23 PM
aNuBiS's Avatar
I think it may depend on if they are bolts, or studs with nuts, and I would bet you could possibly find the info on ARP's site? Or worse case doing a general search on here.
www.ls1howto.com in the head swap part should maybe give you some direction.
Old Jun 4, 2008 | 12:25 PM
99blancoSS's Avatar
^^^ I've used/use the studs and they are re-usable.
The bolt number is 134-3609 for 2003 and earlier and 134-3610 for 2004 and later
Old Jun 4, 2008 | 12:34 PM
99blancoSS's Avatar
Just got off the phone with ARP so more guesses... drum roll please..... YES they are re-usable same as the studs.
Old Jun 4, 2008 | 05:25 PM
JDC's Avatar
JDC
I would think you would torque them the same as stock bolts eccept you can use them again because they dont strech.
Old Jun 4, 2008 | 06:11 PM
99blancoSS's Avatar
No they have specific torque points! The OEM are TTY, you stretch them when you install them.
Old Jun 4, 2008 | 08:06 PM
smask04C5's Avatar
I used torque values recommended by ARP. Head studs were 45, 55 and 65 with supplied ARP moly. I just got a set of ARP main studs 234-5608 for a stroker build and supplied instructions recommend 60 inner, 50 outer and 20 for the horizontal bolts, using the supplied moly. If tightened dry, unplated fasteners consume about 80% of the applied torque just to overcome the thread friction.
