how much rpm !!? help !
Old Jun 6, 2008 | 08:25 PM
randomnine7's Avatar
Default how much rpm !!? help !
i have a forged 347
arp rod bolts and head studs
harland sharp rockers
tsp pushrods
comp r lifters ..
EWP
single belt/pully alternator
25% balancer
and new cam main and rod bearings
how high can i spin it to ?
ima be running alot of nitrous about 300ish and just wondering how hig can i spin it ..
Old Jun 6, 2008 | 08:36 PM
gsxr1k2's Avatar
I'd spin that to 6800k all day and never look back at least thats what I do with mine.......
Old Jun 6, 2008 | 08:43 PM
troopercar's Avatar
6500 easy
7+ if you have big huge man *****
Old Jun 6, 2008 | 08:58 PM
chuckyt1's Avatar
My rev limiter is at 7200. Shift light at 6800. Stock crank, rods and pistons with Katech rod bolts.
Old Jun 7, 2008 | 09:24 AM
JPH's Avatar
JPH
How cares how far you can spin it, strap it down to a chassis dyno and see where peak power is, then make a determination from there on how far past peak you want to shift it at. 300 past is ideal.
Old Jun 7, 2008 | 09:31 AM
NASTYTRANSAM's Avatar
True it could fall off on the power whats the point of hanging it out if you don't need to
Old Jun 7, 2008 | 09:39 AM
PREDATOR-Z's Avatar
You spin it only as high as it needs.
Meaning you shift at a point where you keep the maximum average Hp between shifts, no more no less, all other methods are futile.
Old Jun 7, 2008 | 10:01 AM
troopercar's Avatar
I thought he was asking what is a safe rpm limit to not exceed or go boom.
Old Jun 8, 2008 | 05:41 AM
yes to both ..
looking at how much rpm i can play with .. but i will be shifting at the best rpm to end up in the powerband for the next gear ... 7+ k too much ?
Old Jun 8, 2008 | 10:10 AM
DONAIMIAN's Avatar
Whats the cam look like?
Old Jun 8, 2008 | 11:49 AM
LSWONGTO's Avatar
What size cam do you have?
Old Jun 9, 2008 | 02:35 AM
ms4
fast 90/90
PRC stage 2.5...
and well everything else too .. i knw the camm willpull up high .,.. just looking for hom much rpm its capable of .. im coming from a high hp rpm rotary .. so going form 9.5k to 6.5k is a lil wierd ... lol
