MS3 Cam
Old Jun 10, 2008 | 04:52 PM
sedanman's Avatar
I want to order some 5.3 stg 2.5 heads but my MS3 is on a 111lsa will they clear?
Old Jun 11, 2008 | 07:10 AM
NVR_ENUF's Avatar
Originally Posted by fastvet
So your running the MS3 cam on 59cc heads?
I WAS, yes.....
Mr. Brett
Thanks! We're heading up to West Bend dyno on saturday. Greg is bringing up his Magnacharged LS1 GTO as well. We should be on the dyno around 11-12 if you wanna swing by.
I have a football game around that time, so I probably wont be able to....
c5_ls1_6spd
What kinnd of power did you make?
were your pistons flycut?
what LSA was that MS3 on?
436/392
No
113
Old Jun 11, 2008 | 07:20 AM
LS1C5Vette's Avatar
Yes IF you use a stock MLS gasket BUT ALWAYS check your clearance with clay at the very least, it will take 10 mins out of your time.
Old Jun 11, 2008 | 09:06 AM
fastvet's Avatar
OK, so if you have a pair of LS6 heads and a pair of 5.3liter heads, both at 59cc, does the same principle apply? Another words, you wouldnt be able to run a better cam on one than the other. ?????
Old Jun 11, 2008 | 10:16 AM
fastvet's Avatar
Texas Speed, feel free to chime in.
Old Jun 11, 2008 | 10:05 PM
Tainted's Avatar
can someone confirm his question? im considering the same setup using stock head gaskets as well!
