Fly cut cost
Old Jun 11, 2008 | 07:57 PM
Domexitium's Avatar
Default Fly cut cost
Ok guys I have searched everywhere! I'm just wondering if any of you have a ballpark number as to how much it cost to have the pistons fly cut?
Old Jun 11, 2008 | 08:18 PM
GuitsBoy's Avatar
A lot cheaper if you do it your self. LG used to rent the tools and a hogged out head to use as a guide. Not sure if they still do it or not. Otherwise its probably gonna cost your 2 or 3 bills, assuming the heads are already off.
Old Jun 11, 2008 | 09:20 PM
Domexitium's Avatar
The thing is, i wouldn't have the slightest idea as to how much to cut them. I don't even know whats the deepest i can cut them.
Old Jun 11, 2008 | 09:23 PM
GuitsBoy's Avatar
Well, ideally youll want to measure, but even thats not an exact science cause the cutter is a larger diameter than the valve, and a .090 cut wont gain you an additional .090 clearance. I just cut mine at .090. Anywhere from .075 to .090 is typical, but I wouldnt really go past .100 deep in a stock piston. Its supposedly pretty thick in the area, but I wouldnt go too far, ya know?
Old Jun 11, 2008 | 09:31 PM
Domexitium's Avatar
ya, i get you. So basically if i cut it .090 then it'll be able to take a lift of .090 from the valve? so if i have a cam that has a valve lift of .598 then it'll be able to fit a valve lift of .649? sorry about all the questions dude, but i sure do appreciate your help!
Old Jun 11, 2008 | 11:09 PM
9000th01ss's Avatar
You need to measure and cut bottom line, no exceptions...Why?
You can measure and be fine with one .649 cam.
Then put another .649 cam in with a longer duration, earlier intake valve opening, and you might have .1xx interference.
Duration will cause PTV contact before lift will.
Old Jun 11, 2008 | 11:15 PM
Joey@Tick's Avatar
LS1TECH Sponsor
We charge $210 labor for flycutting.
Old Jun 11, 2008 | 11:16 PM
Paint_It_Black's Avatar
yeah to sum up what 9000 said, max lift has nothing to do with ptv clearance.
Old Jun 12, 2008 | 06:35 AM
GuitsBoy's Avatar
Right, at max lift the piston is usually a good way down teh cylinder. Things are closest right off the seat, where the piton is still near TDC, and teh valve is just starting to open or has not fully closed yet. To know if you really need to fly cut, you have to measure with teh top end mocked up. However knowing how much to flycut is a darker art still. Shoot for .090 and measure again, that shoudl be good for just about anything you can throw at it.
Old Jun 12, 2008 | 07:23 AM
BREWS02WS6's Avatar
$210 isn't near as bad as I thought! Now Im not scared to look into this if/when the time comes...
Old Jun 12, 2008 | 07:06 PM
Domexitium's Avatar
damn i called some local shops here in NM and i was quoted around 1200 to 1400. but that includes removing the heads and everything. I think i'll go a different route. Thanks guys!
Old Jun 13, 2008 | 03:05 PM
Joey@Tick's Avatar
LS1TECH Sponsor
My $210 quote was performing the job on a shortblock. If we had to remove the heads from the shortblock first or even pull them out of the car, the price would of course increase.
Old Jun 13, 2008 | 04:17 PM
9000th01ss's Avatar
Shops that charge that much want to flycut with the pistons off the rods and in a holding fixture, then rebalance everything.
Obviously this is done on engines with full floating piston pins, you can't press pistons off and put them back on an sleep well at night.
$1200-$1400 might be a do it by the book price.
It's cheaper to get some in the head flycutting tools and do it sometimes even with the engine still in the car.
I'd check PTV first and see if you need both cutters, sometimes you only need one.
It's pretty easy for an advanced DIY'er to do with it on an engine stand, using the right procedures and tools.
