Need new shortblock, have questions
Old Jun 11, 2008 | 10:01 PM
Gregg 00SS's Avatar
Default Need new shortblock, have questions
Here's my sob story. Had H/C installed a few weeks ago, car was putting about 100 HP less than expected down on the dyno. Leak down test showed #3 clyinder is dead. Not sure if it's a seal or a crack or what, but planning on just purchasing a short block and going from there. I have a T-rex cam, Patriot Performance S2 heads, Fast 90, etc... that I want to use with my new set up. If I'm going to replace it, I plan to go with a bigger ci short block.
1. Looking at TSP's web site, what exactly is the difference between a rotating assembly and their stroker short block kits? There seems to be a substantial difference in price between the 2 and I'm not exactly sure what the hell I need.
2. Based on my above listed mods, also listed in signature, is there a certain ci short block that would work best for my combination?
Old Jun 11, 2008 | 10:24 PM
ls2 bait's Avatar
id look into a 383 or a 402 if u want to reuse that stuff. the shortblock kit is prob just that as it will include a block where as the others is likely just a rotating assembly and will need to be installed in a block.
Old Jun 11, 2008 | 10:31 PM
Gregg 00SS's Avatar
Roger that. Funny you should reply first. Roy was telling me about your misfortunes today when I was at the shop bitching about my bad luck.
Old Jun 12, 2008 | 09:22 AM
ls2 bait's Avatar
ya it was misfortunate what happened to my old motor. it ran really well. and minus the lifters its still a good motor but i have a feeling the one that is stuck took the lifter bore with it.
Old Jun 12, 2008 | 09:32 AM
99blancoSS's Avatar
I'd like to offer my services to you. I'll pm you with soome information about 402/3's and such.
