Anyone use these rods?
Old Jun 14, 2008 | 12:09 PM
MrElectric03's Avatar
Default Anyone use these rods?
The rods are just under $300 from SDPC and are forged.The listing gives no hp rating, rpm rating or anything of that sort.
26125716Scat Crankshafts6.125" I Beam LS1 / LS2 / LS6 Scat Connecting Rods$298.95
This is the piston kit with rings and bearings, just wondering if anyone had used them or heard good/bad about them.
KITSD32621FSScoggin Dickey Parts Center3.898" Bore, LS1 / LS6 5.7L Forged Piston Upgrade Kit$599.95
I am considering installing forged rods and pistons while I have my motor apart for the H/C swap to better handle the nitrous shot I will run later.
Thanks for the help!
Old Jun 16, 2008 | 09:30 AM
Just got e reply from SDPC, says the rods are rated ~600hp and I should have no problem sraying this setup.
My plans were to spray a 100 shot and see how it goes and with the forged parts I should be able to end up spraying a 150 shot, so we will see how it goes and if I have the $$$ at the time.
