I think I have a problem
Old Aug 15, 2003 | 12:47 AM
Onyx Z's Avatar
Default I think I have a problem
When I was installing my headers, I pulled out the spark plugs and some of them were covered with oil! I am hoping that the PCV is the problem and not leaking valve seals. What are the possible problems other then these? I know this is robbing power and possibly gas mileage.
Ryan
Old Aug 15, 2003 | 07:56 PM
Onyx Z's Avatar
Default Re: I think I have a problem
TTT
Old Aug 15, 2003 | 10:33 PM
LS1derfull's Avatar
oil is getting in thru pcv, but it is so because oil ring expanders on stock rings lose radial tension after like 20,000 miles. This is perfect for a race motor with oil pan evacuation system, but will use some oil in street car and compression rings also come unseated at hi vacuum/ medium rpm 2000rpm+ at part throttle cruising. This puts some blowby in crankcase that pushes oil into pcv system. Ultimately higher tension rings (all 3) would solve issues, but good pcv baffling and evac system will suffice until than. Keep oil out of chambers it ruins fuels octane rating and will cause knock under load.
