Urgent! Need some help problem after rocker install
Old Jun 17, 2008 | 06:30 PM
Cmhatter9SS's Avatar
Default Urgent! Need some help problem after rocker install
Ok. I just change 3rd stock rocker on front of motor pass side. Bolted everything back up. Made sure 22ft#'s on the rocker and also turned the engine with a ratch to make sure pushrod was at its lowest point. Bolted everything back up. Went to start the car and it poped real loud so I tured it off anyone have any ideas? Spark problem? coil back on wrong firing order? Need some help asap thanks
Old Jun 17, 2008 | 06:54 PM
LS1C5Vette's Avatar
What kind of pop? Backfire or some kind of engine noise "pop"?
Old Jun 17, 2008 | 07:06 PM
Mssingkid's Avatar
Make sure the coil packs are all connected, wires are in good condition and are secure to the plugs...
Old Jun 17, 2008 | 07:28 PM
sappy96's Avatar
fuse pop?
Old Jun 17, 2008 | 07:51 PM
everything is a go thanks guys f*cked up to coil packs
