Which heads for G5X2?
Old Jun 18, 2008 | 12:00 PM
JJ 86's Avatar
Default Which heads for G5X2?
What heads do you guys recommend to run with the G5X2 cam? I'd love to have a set of AFR's but I'm don't really want to spend 2k+ for them. What budget brand heads would perform pretty decent for the money?
Old Jun 18, 2008 | 12:27 PM
TXZ28LS1's Avatar
well i know LG loves AFR heads with there cams. i was also looking at the X2 cam and ive read up on guys having good results with patriot LS6/G5X2 setup.
Old Jun 19, 2008 | 12:59 PM
PREDATOR-Z's Avatar
stock valved 243 castings by Livernois. (LS2/LS6)
Bigger valves will reqire flycutting
Old Jun 19, 2008 | 04:34 PM
k-mart's Avatar
I would definately recommend a head with a smaller runner for that cam. Especially if you've got stock gear ratios. I went from Patriot Stage II LS6's to AFR's and the low end difference was dramatic. My advice would be to save up for AFR/TFS heads.
Old Jun 19, 2008 | 09:45 PM
88ls1blazer's Avatar
I vote for livernois stage 2 heads. Definately a great setup for that cam. 2k+ for an aftermarket head that usually makes the same power (sometimes less, sometimes more) just doesn't work in my head
Old Jun 19, 2008 | 10:00 PM
SS DNA's Avatar
No mean to Hijack but Pred, How do you like your cam ? Is it lopey, SOunds like a stealth cam to me
Old Jun 20, 2008 | 03:43 AM
PREDATOR-Z's Avatar
It is stealth, gets the suckers to bite every time. They find out the drama when they hear it scream at 6800
Old Jun 21, 2008 | 06:43 PM
SS DNA's Avatar
Man your setup is sweet!!
Im going same approach with mine...stealth, with lots of low end ...
