Solid roller questions
Old Jun 22, 2008 | 04:45 PM
SSPerformance's Avatar
depends if the heads will clear them my ets whould not clear 3/8s
Old Jun 22, 2008 | 09:37 PM
Juiced's Avatar
if you need 3/8 then the heads should be modified to make them fit, if not when you use a smaller pushrod you'll be losing more in deflection then you will be gaining from a solid roller.
Thats when dual taper pushrods are used to lower valve train weight but retain strength.
you should see the AFR's i have massaged is a understatement
Old Jun 22, 2008 | 11:40 PM
chevydan's Avatar
1.550 springs will work on the afr 225 heads just got to get the pockets cut! That is what i am using.
Old Jun 23, 2008 | 08:01 AM
Noyzee's Avatar
8 second mod
Originally Posted by Brian Tooley
We have any of the TFS heads available in solid roller form for around $2800 complete, and we can also get the new 18 bolt version. For your applicatoin I would use the TFS 235 setup for solid roller, Noyzee on here used our slightly bigger TFS 245 on his solid roller 427 setup and picked up 6 MPH over a competitors 225 head, so they work well. The 235 is all you would want on a 408, anything else would just be too big. Also, we've made over 2 hp per cubic inch with .500" lift cams, so .700" is all you would want. Hope this helps.
https://ls1tech.com/forums/showthrea...971&highlight=
As Brian said, there heads worked PERFECTLY on my set up.
im spinning it to 8200 with no issues, and the car picked up BIG power!!
all i did was call, speek with them told them what i was doing and what i wanted, they did exactly what they got paid to do and im super happy!
its hard to get that servise these days, but TEA is A++
Old Jun 23, 2008 | 11:51 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I have a set of 806 heads that are cut to clear 3/8ths pushrods. It's really not that much trimming. It is a good point to bring up which I failed to mention.
Old Jun 24, 2008 | 03:01 AM
CJJones87's Avatar
Thanks for all the responses guys. I'm waiting for my next day off to call a few engine shops and talk to some builders about the routes they would suggest.
Old Jun 24, 2008 | 01:46 PM
Brian Tooley Racing's Avatar
Thanks for the plug Brad
Almost forgot, our solid roller heads come machined with BIG pushrod holes, and a 3/8" pushrod is fine for .700" lift, we don't go to Manton dual taper until .800" lift.
Old Jun 24, 2008 | 07:03 PM
Pray's Avatar
I was looking into a solid roller as well. When I looked in the comp catalog I found a cam to my liking but was surprised by the spring reccomendation. The cam is an XFI 251/256 .645/.655 113+3. This cam called for comp 921 springs. These things only have 130 on the seat and 400 open if I am remembering correctly. The springs that come on the TEA TFS 235's are 160/450. The guy at comp said they would work fine. I don't know how big of a cam you are going to go with but you might be able to get away with the springs that come on the 235's and save your self some cash.
PS I love my 235's on my 416.
Old Jun 24, 2008 | 08:24 PM
DONAIMIAN's Avatar
FWIW I'm running a PSI spring thats 220 on the seat and 550 open. It fits in the stock spring pocket. I'm limited to right around .600 lift, but thats fine for what I'm doing.
Old Jun 24, 2008 | 08:45 PM
Pray's Avatar
What are you guys with solids seeing gains wise over hydraulics? Do you daily drive them?
Old Jun 25, 2008 | 08:02 AM
Noyzee's Avatar
8 second mod
No problem.
as for push rods, im running comp not the 3/8 ones i forget now what size, i think it was 8.400's i forget now, but im reving to 8200-8400 and have not had an issue
Old Jun 26, 2008 | 04:08 PM
  #32
CJJones87's Avatar
No problem.
Alright. I didn't plan on turning much more than 8k due to stock oiling system. Again, thanks for everyone's input, it all helps lol.
Old Jun 26, 2008 | 04:16 PM
  #33
Noyzee's Avatar
8 second mod
i run it to 8200-8400 when im running out the back door. usually running the class i run i run it to 7600-7800 because i need to slow the car down. good luck
Old Jul 27, 2008 | 08:46 AM
  #34
TLewis4095's Avatar
Daily driving not reccomended....and with the solids keep an eye on the lash, it will tell you if somethings going away. As for power, with no hyd. cushion you get all the profile all the time.
Old Jul 27, 2008 | 01:06 PM
  #35
CJJones87's Avatar
I'm not worried about daily driving at all. The car would be a full track car with maybe some weekend driving.
Old Jul 27, 2008 | 02:33 PM
  #36
Paint_It_Black's Avatar
There are lifters that you can run on a solid profile with non-adjustable rockers.
  #37
Originally Posted by RoDan
Stock style heads back up WAY before .700+ lift usually, I don't know if your gains would be worth it to lift that high.... but thats just my opinion.
depends on who ports them.
Old Jul 27, 2008 | 06:03 PM
  #38
DONAIMIAN's Avatar
I will be DD'ing mine here soon, but I don't have a long commute at all. Not to mention I didn't go too aggressive.
Old Jul 28, 2008 | 03:50 AM
  #39
CJJones87's Avatar
Well I've been talking to a few local people with similar set ups that I would like to run. They are saying I might have a problem lifting the heads for the size shot I want to do (300-400). So now I'm looking at a LSX/454 build. Was looking at getting an LSX Bowtie block and a TSP 454 rotating assembly and possibly a set of World LS7 solid roller ready heads. Don't know too much about LSX set ups though - Do I have to get new sensors/valley cover etc. like I would if I went with an LS2 block as opposed to an LQ9 for a 408 setup or is everything plug and play? Thanks again for everyone's help.
Old Jul 28, 2008 | 10:11 AM
  #40
Noyzee's Avatar
8 second mod
im running a LSX block i set it up for 427 CI 14.5-1 compression, solid roller
im running trick flow/TEA 245 heads l-19 studs. i have yet to hit the car hard at all but with 100 shot and the new heads i went 9.0 148
i have about 50 passes this season on this set up and have yet to remove a valve cover to adjust the rockers. i checked them one time after the first pass and have not touched them since, so im going to guess me spinning my motor to 8500 rpm for those passes is allot harder on parts then a drive down the road.
if you do an LSX build, contact TEA for a set of 6 bolt trick flow heads (mine are 4 bolt, they didnt have the 6 at the time) run good fel pro mls gaskets, and a set of the l 19 studs to 90 foot pounds and call it a day
