Starting to think about winter build up and want opinions
LS1TECH Sponsor
I have all the boltons including 12 bolt with 4.10 gear, all BMR suspension, QA1, Thunder TB, FTRA, ASP Pulley, Hooker LT, ATR cat back, Speed Inc MAF ends, Whisper Lid, LS6 intake, SPEC S3, and a few others. The car is running 12.2 now with no weight reduction.
I want to do heads and cam over the winter. Starting to look at parts now. Here is what I am thinking. Please give me your opinion.
Heads - S2 titanium retainers and dual springs from either RGR, TEA, AS, or Patriot
Cam - Thunder 224 or Comp extreem 224. I want to pass sniff test if needed.
Chrome Molly push rods
Comp R Lifters
SLP pump
SLP timing chain
Yella Terra rockers
ARP studs or bolts not sure on what way to go here
How does this combination sound? I want low to mid 11's at the track. I really don;t care what the dyno numbers are but do care about track times.
Comp R Lifters
SLP pump
SLP timing chain
Yella Terra rockers
