ls1 problems
Old Jun 23, 2008 | 10:05 PM
snaad's Avatar
Default ls1 problems
Hi i have a 98, camaro ss with a cam and portd heads. It has been reving up on its own when i coast to a stop any where from 1500 to 2500 rpms and when driving down the road it cuts out. I was wondering if anyone had any ideas of what could be wrong. thank u Darrin
Old Jun 23, 2008 | 10:09 PM
snaad's Avatar
or has anyone heard of one doing somthing like this before. thanks
Old Jun 24, 2008 | 12:04 AM
Chris Gage's Avatar
It is "surging" or "searching"... have you had the car tuned? My car did this after I swapped the T/B and intake, it was acting like it was re-learning all the different perimeters of air and adjusting the fuel.
Old Jun 24, 2008 | 06:39 PM
snaad's Avatar
It has already been tuned and everything long before this problem
Old Jun 24, 2008 | 06:41 PM
OUTLAWZ RACING's Avatar
vacume leak? Have you touch the throttle body adjustment scew? Any ses light?
Old Jun 24, 2008 | 06:45 PM
snaad's Avatar
no i havent at all i was just driving down the road one day and it startd doing this
Old Jun 24, 2008 | 06:49 PM
snaad's Avatar
Does anyone else have any ideas on this problem
Old Jun 24, 2008 | 07:05 PM
Try changing the TPS sensor and make sure it is plug in.
Old Jun 24, 2008 | 09:16 PM
snaad's Avatar
i already changed the tps sensor
Old Jun 24, 2008 | 09:38 PM
07gsxr750's Avatar
sounds like a vacuum leak, mine did it after fast intake install, the map sensor fit a little loose on the rear of intake and came out while driving, check for vacuum leak.
Old Jun 24, 2008 | 09:45 PM
brad8266's Avatar
If it was ok before I would start by looking for a vacuum leak somewhere around the intake to include all the vacuum hoses.
Old Jun 24, 2008 | 09:49 PM
snaad's Avatar
ya will be somthing to check i had it plugd in to a computer today and it said it had a miss fire but it wouldnt tell us witch one of the 8 it was it also seems like it is loading up and when it is just sitting there ideling and reving up by its self it makes the temp gauge go up. I dont no but it seems like one of the injectors is spraying to much or somthing what do u guys think.
Old Jun 24, 2008 | 10:08 PM
snaad's Avatar
oh and another thing is it only does it when it is warmd up and when i have drove it for a little bit but it doesnt do it all the time that is why i cant figure it out
Old Jun 24, 2008 | 10:56 PM
PassionateZ's Avatar
Maybe its alive!! Like that movie Christina..or Herby
Old Jun 24, 2008 | 10:59 PM
LS1BLKSS's Avatar
Banned Village Idiot
im sure its the TPS my car is doing the same and it gave me a code for the TPS, change that bad boy and your all good to go!
Old Jun 25, 2008 | 02:31 AM
LSWNDR's Avatar
my car is doing th same thing it's throwing the misfire code on the 7th cylinder as of today, 2001 LS1 with a 99 LS1 forged bottom end, ms4, LS6 STG 2.5's milled, 36lbz. injectors, 255 fuelpump, hooker 1-7/8 LT'S, TSP X-PIPE,4.10
Old Jun 25, 2008 | 09:53 PM
snaad's Avatar
ya i wish mine would tell me what cylinder it was tho
Old Jun 25, 2008 | 11:02 PM
LSWNDR's Avatar
yeah i was told today that a bad tune could of fowled the plugs, caused misfire and detination, now that it's tuned running on 7 cylinders i'm gonna change the plugs and wires then go from there, but if it still does it i'm gonna find another tuner for my G ride
