Putting motor back together. have some questions please.
my motor is apart and i will be assembling soon as i buy the new parts.
what is a good head gasket to go with?
i will be running stock heads, probably a stock cam, but i MIGHT be going with an aftermarket cam. nothing huge.
what size and what kind of head gasket should i get?
next question, i am upgrading lifters, and i will be getting ls7 lifters. what length pushrods do i need? and what is a good ratio for rockers?
if i get the cam i will be going with patriot gold dual springs, what rockers should i go with?
ANY help would be appreciated, im new at this.
Most aftermarket cams with stock heads will use a 7.400 pushrod but it's a good idea to check it with a pushrod length checker. The procedure is fairly easy and the tool inexpensive. Here is a thread on this.
https://ls1tech.com/forums/showthrea...+lifter+lifter
