I Have A Block Outta A 06 1500 2wd Silverado Truck Idk
Old 06-28-2008, 10:49 PM
bad2dbone's Avatar
Arrow I Have A Block Outta A 06 1500 2wd Silverado Truck Idk
I Know Its A 6.0 Bt Idk How To Order Pistons What Block R Car To Ask For? Can U Help?
Old 06-28-2008, 10:55 PM
proelky's Avatar
If it's a 6.0L you need a 4.00" bore piston, unless you're stroking it.
Old 06-28-2008, 10:56 PM
bad2dbone's Avatar
naw leave it stock crank and rods just needed replace the pistons my valve dropped mesed it up 4.00 bore piston the motors outta a truck though so wat do i ask for?
Old 06-28-2008, 11:09 PM
ShortChevy's Avatar
Dude I'd love to help but I can't understand a ******* thing you said.
Old 06-28-2008, 11:13 PM
ssfast99's Avatar
yah are you putting the motor into your car or truck because it does not matter. just get 4.00 pistons for a stock 6.0 block or if your going to bore it, get the correct size. i am with shortchevy, dont really understand what the problem or question is.
Old 06-28-2008, 11:18 PM
bad2dbone's Avatar
what i was asking is i have that block and i messed up my pistons do not wanna bore it out are nething needed to see if i would be able to get a stock size piston but aftermarket lk with the valve release
Old 06-28-2008, 11:25 PM
ssfast99's Avatar
126-11514 Diamond Pistons LS1 Forged Dished Piston set w/ -13.7cc Dish, 4.000" BORE / 3.622" Stroke / 6.098" Rods / 1.336" Comp Height / .945 x 2.950 Wrist Pins Included $720.99
for a stock motor. 4.00 bore/ 3.622 stroke from thunder racing
this is just an example because there are more to choose from. just call any of the vendors to the right and ask them for what you want.
Old 06-28-2008, 11:27 PM
bad2dbone's Avatar
alright thank u
