LS1 in reverse rotation
Old Jun 30, 2008 | 10:53 AM
SSuzuki's Avatar
In a boat tho unless he is running a direct drive boat you can purchase counter rotator gearcases for mercruiser or volvo.....So making the motor run reverse wouldnt be worth it.
Old Jun 30, 2008 | 10:55 AM
alamantia's Avatar
http://www.boatdesign.net/forums/showthread.php?t=9524
Old Jun 30, 2008 | 12:51 PM
Engine_HP's Avatar
Originally Posted by alamantia
probably for a boat
actualy there is easier wan than reverse rotation. he can use epicyclic gears as in auto gear or something like that
Old Jun 30, 2008 | 01:09 PM
alamantia's Avatar
if he is looking to bolt in a new engine who wants to get involved with expensive gear boxes and relocating the motor, id rather just try and find out of you can do a revers rotation, thats why they do them like that now.
Old Jun 30, 2008 | 03:23 PM
redtail2426's Avatar
i think he just started the post to see what people would waste the time to respond
Old Jun 30, 2008 | 03:26 PM
hlaalu's Avatar
Well if he had a freshwater boat, or a salt water boat with a heat exchanger and wanted to repower it with a pair of LS1's one engine would have to run backwards.
can't you just change the angles of the props?
Old Jun 30, 2008 | 04:18 PM
70 LS1's Avatar
Conversion master
Wow, a lot of replys. And for some reason I wasn't getting notification of them.
This would be for a rear engine Corvair. The stock Corvair 6 cylinder spins in reverse rotation so to swap in an LS1 it would need to be reverse rotation as well.
The other option is to use a Porsche transaxle that allows you to run forward rotation.
Just seeing which would be cheaper and easier.
Old Jun 30, 2008 | 05:08 PM
slt200mph's Avatar
You are looking at the cheapest and the easiest way to do it.
Here is a Corvair with a LS series engine in it...do it this way and you do not have to phuch around with all this reverse rotation BS.... ... You know that this car will haul azzzz it weighs nothing.
I saw this car on the Hot Rod Power Tour in Evansville, Indiana in 2007..it was kind of a sleeper for sure.......
Old Jun 30, 2008 | 07:33 PM
alamantia's Avatar
And have one push water and one pull water?
Old Jun 30, 2008 | 09:29 PM
shift123's Avatar
He's probably looking into something like this?
http://caravelleboat.com/forum/viewtopic.php?t=2541
Old Jun 30, 2008 | 09:34 PM
slammer454's Avatar
heh. I read about some guy who dropped a regal chassis under one of those and stuffed in a 455, imagine with the G-body suspension parts and a well built LS1!
Old Jun 30, 2008 | 09:44 PM
  #32
tillery's Avatar
Ok the corvair is a mid engine car, sounds like you want to keep it that way. And you sure its not a reverse rotation cam? My 250/292 inline 6 is that way. Its been along while since I seen a corvair set up and it was a bit different like how the accesery drive is. P.S dont let Ralph Nader know. He thinks these cars are unsafe at any speed.
Old Jun 30, 2008 | 11:48 PM
  #33
70 LS1's Avatar
Conversion master
The corvair is rear engine, not mid. And it uses an air cooled horizontally opposed 6 not an inline 6.
Old Jul 1, 2008 | 12:33 AM
  #34
hlaalu's Avatar
no the blades would still be pushing the water away from the boat... hmm how can i explain what i mean
alright so lets say you have this prop. looking at it, it would have to spin clockwise to push water and propel the boat.
so if you have the engine turning counter clockwise, do they make props that have opposite angles like this one i just mirrored in photoshop.
hopefully my thoughts are making sense?
Old Jul 1, 2008 | 05:28 AM
  #35
alamantia's Avatar
yes, thats what has to happen if you have two engines spinning io opposite directions, i thought you meant have both engines spinning the same direction and having opposite pitch blades. You are corrct.
Old Jul 3, 2008 | 01:19 AM
  #36
Tekhombre's Avatar
Other than cam, what would it take to make an LS1 reverse rotation?
Install the crank reluctor reversed, re wire ignition coils, revise crank oil passages and use an external oil pump. Also check cam sensor signal to crank signal timing, this can be done on the cam (LS1) or timing chain (LS2), pin dampener.
I can't picture an LSX in the rear of a Corvair though.
Julio
Old Jul 3, 2008 | 01:28 AM
  #37
99blancoSS's Avatar
Wasn't there a turbo on it as well?
Good Corvair info here
http://www.corvaircorsa.com/vance.html
Old Jul 3, 2008 | 10:59 AM
  #38
slt200mph's Avatar
Way too much work to do reverse rotation and a transaxle...and on top of that trying to get the power reliably to the wheels is going to be major pain...if he puts it in the front and runs a traditional drive train would be much easier and less expensive and more reliable too...the car should be stupid fast with that kind of power to weight ratio....if he puts the motor in the rear he can get a side job doing 1/4 wheel stands on the weekends.
Old Jul 3, 2008 | 02:00 PM
  #39
ss.slp.ls1's Avatar
At the Edelbrock facility in Torrance, CA they have a speed boat powered by a small block Chevy. The prop and shaft were mounted to the front of the crank and the engine was mounted backwards. Just throwing it out there.
Old Jul 3, 2008 | 04:00 PM
  #40
formulaon18s's Avatar
Wait a minute, IF you took all the time to get an LS1 to run backwards for a boat setup wouldn't the boat still pull to one side since one engine is making 350hp and the other is making over 900hp????
