cam head decision help
Old Jun 30, 2008 | 07:19 PM
2004SSS's Avatar
Default cam head decision help
ive got two cams that im interested in but open to others
one is the known reputable tr 224 on a 112 and the other is a guy i know that build ls motors locally specs on it are 228/233 560/575 on a 114 lsa
he also has a set of ls6 cnc ed heads with ss valve and dual springs that will go on with either
my car is pretty stock 02 ls1 camaro just 1 3/4 kooks with a magnaflow( which may change to something like a tsp dual set up that i will make) 4.10 (10 bolt) , ls7 clutch ,fipk, and i will also tune it.
also doing the go to with it ls2 chain , oil pump and underdrive.
i dirve my car about 300 miles a week to and from work and there is some low rpm luggin on the freeways .
im honestly looking for power and will scarifice some but i want a nice choppy idle and would like 425+ rwhp.
Old Jun 30, 2008 | 08:09 PM
'02 WS6's Avatar
PM Patrick G, he'll custom grind you a very nice cam to your liking! Unlike your second cam listed (much duration/not so much lift) he has almost perfected the low duration/high lift cams that make TONS of power and drive exceptionally well. Out of your two listed I'd prefer the TR224, very reputable DD cam on here!!
Old Jun 30, 2008 | 08:13 PM
Elcaballoloco's Avatar
I agree on the Patrick G. cams.
If you are just looking for off the shelf parts, there are plenty tried and proven cam/head combos out there to easily make 425. Just look right for the sponsors or do a search which is a better tool than any to help you gather results from others setups and what worked and what didn't work for them.
Old Jul 1, 2008 | 06:05 PM
2004SSS's Avatar
yeah i pmed him and got a good answer, thanks pg
what injectors does everyone run with a h+c upgrade ? sopmething easliy tuneable , bolt in and have the same plugs.
Old Jul 1, 2008 | 06:38 PM
tasilver's Avatar
My engine just went in my car today. I should have it back by Thursday. I had the TR224 112lsa and cnc port valve job Ls6 heads installed. I also had the underdrive pulley, port and polishd throttle body installed. I have a 411 gears and I am getting the car dyno tuned next week. When the car goes to get tuned I am installling the new style cobra injectors. I bought them from NEW ERA, I think they may still be on sale. I will post my numbers next week.
For the most part my set up is the same for the TR224 cam as you are looking at.
Old Jul 1, 2008 | 06:39 PM
2004SSS's Avatar
also will i need a walbro 355? or will the stock unit suffice? id rather not add a fp guage .
Old Jul 1, 2008 | 06:42 PM
tasilver's Avatar
I am running the stock pump. The injectors are just plug and play. I did not want to max the stock ones out.
Old Jul 1, 2008 | 08:30 PM
'02 WS6's Avatar
popular ones are lucas 42 and svo or blue top 38+
Old Jul 2, 2008 | 04:12 PM
conde'strans's Avatar
I went with #42 lb Ford Green Top injectors for my PRC 5.3 Stg 2.5/MS3 combo.
Old Jul 7, 2008 | 07:24 PM
2004SSS's Avatar
ok well i have pretty much made up my mind i went with a patrick g cam and ported ls6 heads.
is the stock fuel pump going to work or not , i really need to a for sure yes or no . i dont need dropping fuel press resulting in inconsistant afr's. i want to do it right i need this thing reliable.
i also need a good recomendation on injectors i want the svo green tops but would like something a little less expensive. i think the green tops may be a bit overkill but dont no for sure. id like my idc to be about 90%.
