is there a cam for stock intake manifold?
Old Jul 7, 2008 | 02:39 AM
razorclaw99's Avatar
Default is there a cam for stock intake manifold?
Been looking around and everything requires atleast a ls6 intake. Im on a budget here and am looking to keep the stock ls1 intake manifold. Is that possible ? I'd like atleast or around 380rwhp. I'm not sure if id like the CheaTR cam..Seems too mild. Will a 224tr or 228/228 tr work with a stock ls1 intake manifold? OR be up to potential?
Thanks
Greg
Old Jul 7, 2008 | 07:34 AM
ProjectDuStU's Avatar
Thanks
Greg
Larger cams get more air in the motor.. so if you upgrade your cam your choke point is going to be the intake if you stay with a stock ls1. 380 is possible but you will meet your goals much easier if you pick up a ls6 intake. So to awnser your question, any cam you slap in there will work with a ls1 intake but none of them will be up to full potential.
Old Jul 7, 2008 | 11:25 AM
kingsey's Avatar
Spend the 300 bucks and get the intake the benefits are well worth the 300 bucks dude.
The 224 cam is good too
Old Jul 7, 2008 | 12:51 PM
PREDATOR-Z's Avatar
230/224 .612/.604 111+4 LSA
That will do the trick, if you like let me know, I'll give you the specs
Old Jul 7, 2008 | 01:01 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Like said there is a cam choice out there, but then again, if your doing the job once, at least do it right, there is def hp being left on the table.
My situation is that I have a ported 90/90 and with my cam choice 228/230 @ 112 that my MAF sensor and possible fuel is maxed out.
With your combo, that should not be the issue but for a little extra work you can see a healthy gain on RWHP.
Old Jul 7, 2008 | 05:25 PM
TAQuickness's Avatar
How do you max out the MAF with that combo?
Old Jul 7, 2008 | 07:34 PM
scidav87's Avatar
an ls6 intake is worth half as much as the cam itself, in alot of ways....alot cheaper too
Old Jul 7, 2008 | 08:56 PM
PREDATOR-Z's Avatar
It is not a matter of maxing out, it is a matter of ID while having a 90/90 at its back.
Take a straw and suck through it, now pinch it in the middle, which gives you more air?
