gouge on head sealing surface
Old Jul 3, 2008 | 09:39 PM
jhall's Avatar
Default gouge on head sealing surface
I am about to install some patriot stg 2 ls6 heads but noticed that there is a gouge on the top sealing surface to the valve cover. It is on the high side of the head and shouldnt see alot of oil but was wondering if you guys think i should just use a silicon or high temp rtv or something like jb weld to fill in the gouge.I am concerned that if the jb weld ever gave way something bad would happen but am not sure if rtv will seal properly. Thanks for any tips.
Old Jul 3, 2008 | 09:47 PM
Grimes's Avatar
you're probably fine with just the rtv. I seriously hope that you never get enough oil up in the heads to make it to the level of the valvecovers (besides normal spray)!
Old Jul 4, 2008 | 09:57 AM
jhall's Avatar
I am concerned about the spray, i was thinking about forming some rtv in the gouge, letting it dry and then putting the valve covers on. Hopefuly i will not have a leak. The gouge is pretty deep...
Old Jul 4, 2008 | 10:17 AM
Randy WS6's Avatar
That will work just fine
Old Jul 4, 2008 | 10:47 AM
02 BLK WS6's Avatar
RTV and forget about it.
Old Jul 4, 2008 | 11:05 AM
99blancoSS's Avatar
how big a gouge? post a pic if you can. Most likely it wont be an issue the gasket is pretty good about sealing if you dont get it twisted..lol
Old Jul 4, 2008 | 11:35 AM
moeZ28's Avatar
If PTV isnt an issue, mill the heads till the gouge goes away!!!
Old Jul 4, 2008 | 11:44 AM
beedo's Avatar
Cant mill the valve cover sealing surface
Old Jul 4, 2008 | 12:15 PM
sappy96's Avatar
use devcon putty to fill it Just make sure its sanded to where you want it before it fully cures.
Old Jul 4, 2008 | 10:03 PM
moeZ28's Avatar
Oh ****...gotta quit talking to people and reading at the same time...jeez!
You can use some gasket maker or silicone. I had to use some on my old car and the grey gasket maker worked great!
Old Jul 5, 2008 | 01:52 PM
hirdlej's Avatar
Show us a picture of it. You could have it welded then grind flush
Old Jul 5, 2008 | 03:24 PM
jhall's Avatar
Here is a pic, my camara is not the best or nor am i taking pics
Old Jul 5, 2008 | 10:21 PM
hirdlej's Avatar
If you want to do it right take it to a reputable machinist and then just have him use an end-mill and go around the whole top of the head taking the material down 'til it's completely smooth.
