Help! Arp Head Bolts!
Old Jul 4, 2008 | 12:20 PM
Michael V's Avatar
Default Help! Arp Head Bolts!
I just started installing my ARP head bolts and noticed they are tight in the holes. Yes I cleaned out all the holes and chased them using an old bolt cut on one side to catch debris. I measured them and they seem to be .005 to
.007 bigger on the thread OD than the stockers ( Stock .423" vs ARP .430")
Has anyone else found this? How the hell do you get a correct torque?
MikeV
Old Jul 4, 2008 | 12:36 PM
massls1guy's Avatar
I found the same thing. I just chased the holes a few times with the ARP bolts and then it loosened up enough. Make double sure that there is no coolant left in the holes too.
Old Jul 4, 2008 | 12:40 PM
Michael V's Avatar
I can't believe that much differance!. I chased all the holes, then sprayed cleaner in each one, then attached a small plastic hose to my compressor and blew each one out with 100 psi. I put the torque wrench on one and it turns easier than I thought.
Mike
Old Jul 4, 2008 | 02:48 PM
Randy WS6's Avatar
Watch about using air to blow out the holes, The air just blows the Debee up threw the threads that you just cleaned out, I use the same hose method but attach it to a shop vac to suck the Debee out to keep from contaminating the threads.
