Tooks for checking PTVC
Old Jul 3, 2008 | 06:38 PM
LS1C5Vette's Avatar
Default Tooks for checking PTVC
Where could I get all the tools needed to check my PTV clearance (checking springs, dial indicator, etc) my cam has already been installed so I wont be able to degree the cam when I add my heads next month.
Old Jul 4, 2008 | 04:12 AM
LS1C5Vette's Avatar
To the top
Old Jul 4, 2008 | 04:20 AM
Engine_HP's Avatar
How is it posible to measure the PTV wile the heads are installed and the engine is in the car ?
Old Jul 4, 2008 | 04:35 AM
camaroguy26's Avatar
I'm confused when you say you can't degree the cam cuz it's installed? You can only do it when it's installed. Degreeing it just double checks all the manufacturer's specs and makes sure your camshaft is in sync with your crank. But you can get PTV tools through summit or jegs, a local race shop might have some too.
Old Jul 4, 2008 | 05:52 AM
Randy WS6's Avatar
When you degree a cam you must have adjustable timing gear set and most that you find is set to adjust in 2* (+ or -) increments, and if you find a cam that is out that much from the factory , i would look in to finding another cam. Most high end cams these days are ground extremely accurate. If your degreeing your cam to help check the PVC you might be to tight to begin with , You need no less than .100" int & .080" ext. piston to valve clearance.
Old Jul 4, 2008 | 07:14 AM
LS1C5Vette's Avatar
Ok does anyone have the link to get all the tools?
Old Jul 4, 2008 | 08:20 AM
HavATampa's Avatar
If you do buy a kit with a degree wheel, find one with a smaller wheel like a 9" so it doesn't hit everything in the engine compartment. Example:
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 4, 2008 | 09:03 AM
vettenuts's Avatar
Wondering if rather than a degree wheel you can mark the damper or pulley. If you know the radius you can figure out the distance between marks and just mark it every 2 degrees before and after TDC for 20 degrees. You don't have to be super accurate on TDC like when degreeing a cam since you have a sweep that looks for the minimum clearance. What gaskets are you using for the installation?
Old Jul 4, 2008 | 03:00 PM
LS1C5Vette's Avatar
Stock MLS gaskets
