Need help with cutom grind
Hey all. Been doing a lot of research again for my new used 02 Z06. I am looking to pick a good custom grind for my car. I am hoping some of you cam experts could chime in. I drag maybe 5 or 6 times a year at the strip. More importantly I do open track days about 6 times a year. I plan on doing a cam, longtubes with no cats and electic cut outs for track duty. Otherwise I will be going through the stock Ti's. I plan on leaving the heads alone but will upgrade the valve train when I do the cam. What I am looking for is a cam that will be the best for all of these needs. I have looked into the ASA cam but figured why limit the lift that much if I am not running sactioned events. What would you guys think of a cam in the 240/240 ish duration on a lift from around .550 to .580 on a 110 lsa. Any ideas and imput would be appreciated.
Thanks,
Robert
Thanks,
Robert
I would recommend something in the mid to upper 220s for intake and lower 230s for exhaust, lift in the low 600s and an LSA between 111-112. Lots of shelf cams in this range and some really good custom cams too.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I agree with Patrick, plenty of off the shelf cams out there that will do what you want them to. Texas Speed 228, or maybe even 233/239 depending on what RPM range youre used to running.
I want to keep the lift below the 600's to keep spring life up. I dont mind changeing springs but they are going to see a lot of abuse. So maybe I will go with a custom grind in the 230's with a 580 lift.
Lift doesn't hurt springs as much as ramp intensity. For example, Comp's XFI lobes are more spring friendly than XE-R lobes even though a 224 XFI lobe is .609" and a 224 XE-R lobe is .581". You can't run 918s with XE-R lobes but you can with XFI's (in a pinch).
__________________
