Problem With Cam Swap (Stripped Bolt)
Old Jul 10, 2008 | 12:35 AM
tilly's Avatar
Default Problem With Cam Swap (Stripped Bolt)
Hello,
I am currently putting my motor back together. Everything waqs going smoothly when one of the Cam Cover bolts, (the cover that sits behind the timing gear that bolts to the cam shaft) decided to take all the threads out when I went to torque it down to 18 ft/lbs.
Should I: [I know option A is the book way of doing it]
A: drill and re-tap that hole [I do not have the tools to do it or a truck to transport the motor to a machine shop]
B: put a ton of thread lock into that hole and hope it doesn't walk out into the timing gear. (bolt does thread in but does not tighten)
C: leave it out, there are 3 other bolts tighten down to spec with lock tite on them, you should be fine with the other 3 bolts
D: LS1's stink, sell the car and buy a mustang
I am open to other options.
Thanks
Tilly
Old Jul 10, 2008 | 12:37 AM
180ls1's Avatar
should have just made a poll thread. I would retap it.
Old Jul 10, 2008 | 04:35 AM
vettenuts's Avatar
Option E. Install a heli-coil. Your other options won't work.
Is the hole blind? This is easy to do, but if it is the open hole (I think there was one) it will be more difficult because of chips but not impossible.
Old Jul 10, 2008 | 09:06 AM
Mr. Brett's Avatar
Heli-coil it.
Old Jul 10, 2008 | 10:09 AM
PERFECT Z28's Avatar
+ 1 for the Heli-Coil
Its a very easy to install the Heli-Coil!
Old Jul 10, 2008 | 11:11 AM
vettenuts's Avatar
Revised my prior post as I meant to say one of the four holes opens into the block, from what I remember. That hole will require some special precautions. I thin the other three are blind holes.
Old Jul 10, 2008 | 08:55 PM
tilly's Avatar
THe bolt that stripped is the center top bolt on the cover.
Old Jul 10, 2008 | 09:11 PM
nova2427's Avatar
+1 on the heli-coil
Just a little piece of advice, DON'T DROP A BOLT IN THE OIL PAN!!!
I left the motor in the car during my head/cam install and it took me a week to get it out.
Old Jul 10, 2008 | 09:17 PM
DVS99TRANS's Avatar
I'm getting ready to helicoil a bolt hole on my oilpan. i called Autozone and they rent the kits. Just need to know what metric-size bolt your going to do. I'm fretting it but is the best thing to do. Atleast you have room to work with as I will not
GMTECH4's Avatar
i say heli-coil and red loc-tite, i would also use plenty of rags and put some glue around drill bit and the area you will be drilling to catch as much shaving as possible and take your time be careful not to drill too deep.
Old Jul 11, 2008 | 05:09 AM
vettenuts's Avatar
Red loctite may strip out the heli-coil if ever removed again.
Old Jul 11, 2008 | 09:28 AM
Grimes's Avatar
another vote on the helicoil. I would definitely not take a chance with that bolt at all
Old Jul 11, 2008 | 10:17 AM
slt200mph's Avatar
Use grease insead of glue to catch your shavings..
Old Jul 11, 2008 | 04:19 PM
Mr. Brett's Avatar
Yeah, grease is a good idea to catch the shavings. Glue, not so much.
