ETP Headed guys...pushrod length?
I've got a set of ETP 225's on my 346, and I checked the pushrod length awhile back, so they *should* be right.....But I was wanting to check and see what lengths you other thick deck head guys are running.
The ones I have are some chrome moly, from TSP, 8.150's if I remember correctly.
thanks,
-Will
thanks,
-Will
With that length pushrod, I would seriously consider a larger diameter like 3/8". IF the 3/8" won't fit, then 11/32" OD would be my next choice. The stiffness is a function of length and those are getting very long. Couple with stiff springs you may have a resonance in the system that kills power.
I have 62cc combustion chamber size, but dunno the amount milled from stock (milled by ETP) and I am running 8.10", which give me about .060" preload on LS7 lifters. The valvetrain is extremely low noise - less noise than my last cam on XE lobes and I am now running LSK - LOVE the new cam, it is utilising the benefits of the ETP heads very well.
Cheers,
Macca
Cheers,
Macca
vettenuts,
I ordered custom chrome moly pushrods through TSP, they are larger![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
macca,
Thanks for the reply...and glad to hear you like the lobes, I'm trying them out with my latest cam.
-Will
macca,
-Will
My AFRs peak at 12.2:1 at present, so there is still a fair bit of timing that it will be able to take and I reckon I'll be even more happy with the result after I've had the tune tweaked. I reckon there is at least another 10-15 hp to be found once the timing is added.
You will love the LSK lobes and my valvetrain is now actually a tad quieter than the XE lobed cam I took out - go figure?!?
Here is a copy of the dyno sheet, done on a brand new DD twin-retarder chassis dyno:-
![](http://i324.photobucket.com/albums/k339/macsen8r/HSV%20VX%20Senator/DynoSheet100708224228PwrTracEff.jpg)
Cheers and good luck with yours,
Macca
