MorganCam
Old Aug 22, 2003 | 06:13 PM
Ravenous T\A's Avatar
Default MorganCam
Hey is anyone using the MorganMotorsport's 224/224 .570/.570 114 cam? and if so with stock heads what kind of power are u seeing on the dyno. and how does it compare to the TR224?
Old Aug 22, 2003 | 09:17 PM
x phantom x's Avatar
STF veteran / 10 second club
Default Re: MorganCam
I highly doubt its much different from the TR224 or the TSP224 or the MTI224 etc etc etc.
Old Aug 22, 2003 | 09:19 PM
John02SS's Avatar
Getting info on this cam is like pulling teeth! I've tried a couple of times in the forums. I'm probably gonna go with the TR224 due to the fact we know it makes HP.
Old Aug 22, 2003 | 10:01 PM
SunsetWS6's Avatar
The TR cam is very good but Mike Morgan knows his stuff too so either way you go you'll be fine.
Old Aug 22, 2003 | 11:18 PM
John02SS's Avatar
Mike is very knowledgable! Glad to see him working through and getting MMS back were we need it! I wish more info such as idle quality, dyno #'s, and the like were available for some of MMS offerings.
Old Aug 23, 2003 | 12:04 PM
mjf454's Avatar
I have a MMS 224 and make 401 rwhp and run 11.65. The cam is great, drives like stock untill you get on it. I would recomend it. Mine is the old one with .561 lift on a 114lc. Quarter mile times have way more to do with car set up than a few hp either way.
Old Aug 23, 2003 | 04:42 PM
99 Black Bird T/A's Avatar
See this link for some additional discussion on the MMS 224 cam.
https://ls1tech.com/threads/showflat...=7&fpart=1
BTW the MTI C2 has more lift and slightly more area under the curve than the MMS cam. The ramp rates are very similar.
