Need Help
Old Jul 14, 2008 | 09:03 PM
Z/28_rice_eater's Avatar
Default Need Help
I am installing some new push rods in my 99 LS1 Z28 this week but need to know If there is a certain way to torque the rocker arms back down or do i just put them on and torque them down? Also I need the torque specs. Thank you in advance.
Old Jul 14, 2008 | 09:06 PM
brad8266's Avatar
Just slap them in and torque to 22 ft-lbs.
The manual says to torque down the rocker when that cylinder is at TDC but I have found that it is not required.
Old Jul 14, 2008 | 11:49 PM
hmm, ok. Ill probably try to get each cylinder as close to TDC as i can and then torque them all down.
Old Jul 15, 2008 | 09:05 AM
brad8266's Avatar
If you search you will find the procedure, you get one cylinder to tdc and tighten half the rockers then turn it over once and tighten the other half.
