doing my cam swap..
I had done a spring and pushrod swap a WHILE back as what I had read was "oh my gosh all these cars are bending pushrods and such, everyone needs chromemoly pushrods..." thats basically it in a nutshell. Well that was all coming from the guys who over-REV their cars and beat the ever loving **** out of them. SO, i bought new springs and pushrods, it was a worthy investement but just not at the time.
Also get new Viton valve seals for the stems.
Viton valve seals for the stems... can you point me where to get those?
also, when I order a new ls1 timing chain, should I go ahead and get all new gears? the motor only has 33k on it
Now, befire the ranting begins, if the car was a 98-00 model or if I had 60+K miles on it...then yes, I'd change the pump/chain. But at 30K? No....
Just my $0.02.
But, unless you have reason to believe one is going bad.....the stock lifters should serve you fine.
then I think i will be good to go.
can you get the pushrod length checker at advance or some parts store like that?
