Need advice FAST!
I have the shortblock together with camshaft, damper, water pump, oil pan, front/rear covers, clutch assy, and bellhousing all in the car now.
So I'm looking at two options, but if someone has a different opinion PLEASE let me know!
1) Lay down some sheets of plywood, set the engine on a cart, lift the car up with my engine hoist and roll the engine out to work on.
2) Leave the engine on jack stands, lift the car up with my engine hoist, build some sort of frame to set the car on so I won't be scared of getting crushed, and work on the engine underneath the car.
Jack the car up, put it on jack stands, put the tranny in.
The wiring harness is a breeze once the rest of the motor is in place.
Im a little too far away to give you a hand but PM me if you have any problems.
