The cams keep getting bigger - are the cars still drivable?
Re: The cams keep getting bigger - are the cars still drivable?
I have an XE-R 228/236 112 in my car, and no matter what I do the startup problems will not go away. It's annoying but I can live with it. Other than that it behaves ok with some occassional surgeing and a stall once in a while.
Jordan
Jordan
My TR220/114 cam will not idle in first without a little bucking. If you want it to idle in gear, go with the '02 Z06 cam.
. . . I need something that can creep uphill in a parking garage at 1000 rpm if need be. Can tuning let the car do that with X size cam and stock cubes?
I hate to do this since a LOT of companies that offer tuning might put contracts out on those that offer the knowledge there buuuuuut there is a forum that exists solely for tuning now
If you get anything other than stock-like drivability from a baby cam like mine then either the tune is grossly incomplete or other things are wrong with the car.
In short: there should be no reason why any of the cams mentioned in this thread couldn't be tuned to NEVER die at a light or on off-throttle deceleration; furthermore, cold or hot starts should be no problem as well.
I have a stock 346 w/the 230/227 112 X1 from MTI with A4, 4000 stall and Jayson tuning. The thing starts right up cold/hot doesn't matter and quite RARELY does it stall out. I'm not saying it will ever be as smoothe as what a stock cam would be but ****...if you wanted that smoothness then don't mod your car.
I don't mind having to tune my car or spend a lil extra doing things to make it purr like a kitten w/that big of a cam on stock cubes...not when a smaller cammed or stocker pulls up next to me when we're cruisin and decide it's time to mat the throttle...I always love the look on their faces as they have to pull back up to my window w/their mouths hanging open.
Super Moderator
Guys running a TH350 or TH400 avoid many of the idle issues. Most of these guys are running a full manual valve body with no tranny braking for first or second gear. Thus there is very little load on the motor while idling. This is one way to get around idle issues with an auto
i think it is complete BS when i hear these guys with HUGE 232/240 cams and say they idle near stock on these motors. it is rough. i know it.
Super Moderator
Depends on who built your tranny, but most full-manual valve bodied trannys don't have the bands inside that cause the tranny to load in 1st or 2nd gear (while off the gas). This way, when you blast down the track and cross the line, you can throw the tranny up into 1st gear and coast onto the return road. Hence the meaning of "no tranny braking".
The fact that the tranny has no internal bands to cause low gear braking, and that you will have a loose converter, means you will have very little load on the motor at idle. The motor won't start loading until the converter starts to flash.
#32
As someone said above, gears, and more cubes both make this easier to accomplish - and they are both an option for me.
I think my question is the same one a few others have - how far can you go with the cam and still be at stock drivability levels? Some report tuning can get monster cams to be daily driver friendly, some report that a TR220/114 can't idle along in gear without surging(WOW, really? bad tune?)
The more folks who post up with their experiences, the more info we have to figure out what is going on.
#33
!LS1 11 Second Club
Based on the info you read, you just have to make an educated guess as to what you want, install it, and see what you get. It's a case by case basis as to how your setup responds to a cam. My setup needed some mild tuning to get it to idle (and it's a 'small' cam!), then I did a full tune and this squeezed another 20 hp out of the cam. It's controlled voodoo, you just gotta dive in and do it.
-AND, you always end up thinkin' "shoulda gone bigger!"
#34
Based on the info you read, you just have to make an educated guess as to what you want, install it, and see what you get...-AND, you always end up thinkin' "shoulda gone bigger!"
#35
The thing I'm worried about, is my driving style requires a good bit of time under 1500rpm - stop sign to stop sign around campus, driving through the apartment complex, cramped parking garages, etc....
#36
I have tuned some of the G5X-2 cars to start and idle so smooth I once had a request to roughen up the idle some. Some cars idle pretty decent with a stock tune, others after a little tuning work, and some take a couple of rounds before everything is ironed out. Haven't encountered one yet that I can't make start and idle without surging issues.
#37
Two words for cold and warm starts. VOLUMETRIC EFFICIENCY TABLE. If you don't tune your car and have some shop tune it and they don't know this then take it to some one else. I just came back from Corvettes of Carlisle and after standing at the dyno all day and seeing heads and cam corvettes only make 380 at the wheel (and this was max except for a cartek car which made 427) and 11.5 a/f ratios it made me sick.
#38
I have a 242/242 .65/.65 114LS solid roller in my 346. It starts quickly and idles quite nicely at 850 RPM, and likes to spin to 7500. I don't daily drive it right now (it's at LG getting a rollbar), but I wouldn't hesitate to do so if the car were here. But I really gotta get the A/C fixed (blown compressor). That's the worst part about its daily driveability rightnow. It's driveabilty isn't drastically different than the B1 cam that I had in the old motor.
Err, just ignore the manual rack and the Madman torque arm.
-Andrew
-Andrew
#39
get something in the 224 range...It will be a lot better for a normal style driving....start getting bigger and you get more power...but driveability starts to go away...and Idle has to be higher....
You can still put up some way respectable #'s with a 224...and you'll have a little more on the safe side for long term...especially if you spray it or blow it for more power.
I have the X1...but I have no plans of putting on nitrous or a blower....and I am semi-used to a big cam and the slightly different driving stle I will need because of a previous Beast I owned....
unfortunately..you cant have your cake and eat it too...theres gotta be a little bit of givew and take....more normal driving and a little less power...or more power and less driveability.
#40
I have a FMS 226/226 .575/.575 112lsa. It's very streetable and has a great lope. The throttle body needed to be drilled out a bit, but after that it idled very well.
