im getting a ms3 installed what do i need
Old Jul 15, 2008 | 07:05 PM
Scott02WS6's Avatar
Default im getting a ms3 installed what do i need
i have a LS2 timing chain, chromely pushrods (7.400), patriot spring (.650 lift) what else will i NEED?
Old Jul 15, 2008 | 07:33 PM
Foys_Z's Avatar
as i was told because i am doing the same thing, you might as well get a ported ls6 oil pump. i think thats about it. i went with an adjustable double roller myself. everything else seems to be there
Old Jul 15, 2008 | 07:36 PM
im2fast4u98z28's Avatar
don't forget the timing cover gaskets and especially the oil pan gasket. if you don't change them they will leak.
Old Jul 15, 2008 | 07:41 PM
b00sted's Avatar
Not true...if you don't maul the gasket when you take it apart. They're o-ringed metal gaskets...They're reusable.
Old Jul 15, 2008 | 07:56 PM
tried it twice and leaked both times.
Old Jul 15, 2008 | 09:03 PM
second_2_none's Avatar
depending on the miles of the car, get some lifters. it sucks cause you have to take the heads off to change them, but if your car has pretty high miles its pretty important to change them out.
Old Jul 15, 2008 | 10:07 PM
Datzneat's Avatar
Might as well do the U/D pulley too!
