Help!!
Old Jul 16, 2008 | 05:01 PM
2001blackcamaross's Avatar
Default Help!!
i have oil in my radiator fluid wtf is that?
Old Jul 16, 2008 | 05:03 PM
smokintiresz28's Avatar
intake gasket
Old Jul 16, 2008 | 05:37 PM
FCar2000TA's Avatar
Veteran: Air Force
or a cracked block
Old Jul 16, 2008 | 08:23 PM
99blancoSS's Avatar
Think about the cooling passages and where do they come in contact with oil?? DO you have an automatic and cooling lines going to the radiator maybe?
Old Jul 16, 2008 | 09:45 PM
i have a 6 speed
Old Jul 16, 2008 | 10:03 PM
OUTLAWZ RACING's Avatar
Oh time for some head gaskets!
Old Jul 16, 2008 | 10:05 PM
5.3LJimmy's Avatar
Most likely gonna be blown head gaskets. Has the car recently been overheated or do you spray it?
Old Jul 16, 2008 | 10:17 PM
yes it was overheated
Old Jul 16, 2008 | 10:32 PM
99blancoSS's Avatar
headgasket sounds like unless you really overheated bad and cracked something.
Old Jul 16, 2008 | 10:40 PM
thanks a lot for your help guys i really appreciate it
Old Jul 16, 2008 | 11:18 PM
Weezzer's Avatar
Is it red???
Check your ps/oil cooler for internal leaks and/or corrosion, sounds to me like it took a dump on ya and is leaking ps fluid into the coolant...
Look into the PS reservoir, is it milky?????
Old Jul 17, 2008 | 09:05 AM
FCar2000TA's Avatar
Veteran: Air Force
Severe overheading can warp the heads too, I think.
Old Jul 17, 2008 | 09:30 AM
any time u get aluminum hot they need to get resurfaced a machine shop can do that fairly cheap i say no more than 40 a head.
