Flow #s for Stock Heads?
Old Aug 23, 2003 | 05:53 PM
2000Z28M6's Avatar
Default Flow #s for Stock Heads?
Just for informational value. Can someone post the specs and flow #s of the stock LS1 heads.(i.e. valve sizes, rocker sizes, flow #s) Thanks
Old Aug 23, 2003 | 06:10 PM
malibu350's Avatar
Default Re: Flow #s for Stock Heads?
Here are the stock LS1 head flow numbers:
Lift: .200 .300 .350 .400 .450 .500 .550 .600
137 187 207 223 228 237 242 243
Old Aug 23, 2003 | 06:16 PM
malibu350's Avatar
Forgot to add the valve size and rocker size
rockers: 1.7:1
valve size: 2.00 and 1.55
Old Aug 23, 2003 | 06:31 PM
2000Z28M6's Avatar
Thanks malibu350!
Old Aug 23, 2003 | 08:44 PM
ne14a6t9's Avatar
Jason from thunder has a print out from there superflow bench, he has it in a few of his posts do a search under his name and you will see what all the heads flow
Old Aug 23, 2003 | 10:58 PM
BergerMan's Avatar
I think this is the info you are looking for...
Stock LS1 Head:
Stock LS6 Head:
Old Aug 24, 2003 | 02:53 AM
2000Z28M6's Avatar
Seems like a lot of flow for stock heads, is 20-25hp really worth $2000+ i wonder? I think I'll work with the stock for now........
Old Aug 24, 2003 | 02:58 AM
beardWS6's Avatar
More like 2900 for MTI S2 heads. And yes it is worth it. Everything works as a system. When I tuned and put 100 wet shot on I got 135rwhp with it! Better you breath, the faster you will run Not bad numbers for A4,12-bolt and all. And Tuned safely!
Old Aug 24, 2003 | 02:41 PM
BergerMan's Avatar
The LS6 heads will not show much gain with your stock LS1 cam. Now its a different story if you decide to drop a nice cam in it, then the stock LS6 heads will show their stuff. Now you are ready to get them ported later for even more hp.
