how are 250cc intake runners????
the heads I am getting are dart 225's 63cc chambers cncd to a 250cc intake runner if that helps
Theres a lot more to a head then cc and flow numbers. but anyways for a stock 3.9 inch bore i think this would be too much just becuase they do open those chambers for a 4 inch bore and run a 2.08 valve. unless they have revised it for a 3.9 bore which i dont know about.
-Anyways, the point is that a 250cc runner will work just fine as long as its meant for a 3.9 bore and is a match to your cam. Just my .02 though
Good luck, post up your results when you get them!
