Knocking question
Old Aug 23, 2003 | 09:34 PM
SuperSideways's Avatar
Default Knocking question
When I start it up the engine has a mild knocking noise for about 5 seconds then quiets down and goes away. Is this normal, or do I have a bent pushrod or something? I have a 2001 SS with 30k miles on it, and the oil pressure is normal.
Old Aug 25, 2003 | 09:49 AM
robertbartsch's Avatar
Default Re: Knocking question
..could be piston slap.
this is a GM defect...bad rings and pistons cause this very common problem...
Old Aug 25, 2003 | 01:07 PM
So is this something I need to fix or just have to live with?
Old Aug 25, 2003 | 01:17 PM
Vents's Avatar
depends on your time/ priorities. most likley piston slap, but it will get progressively worse with time.
