g5x2 cam on stock stuff???
I am thinking about one of these but do not know If I can just put it in....Do I need reliefs??? is it safe for PtV clearance???
Brian Tooley
Brian Tooley
I'm just curious but what spring did you break, a REV? How many 987's have you heard of breaking so far? I'd imagine the 918's wouldn't hold up too well and I have heard quite a few of the REV springs breaking.
I want some MEan Lope...and MAd Power....
Brian Tooley
Brian Tooley
The Comps 987 springs aren't really any better than the 918's which only go to a .600 lift.
If you put in springs that weren't made for the G5X2 lift of course it will break.
The G5X2 is fine for a daily driver, but you need the right springs to begin with.
BTW, LG sells all the parts needed as a kit.
I talk to dozens of people a day, many are not going to post their bad luck with a sponsors parts, or the posts get deleted. Did I mention that we probably sell more LS1 heads then anyone in the country?
"If you put in springs that weren't made for the G5X2 lift of course it will break."
So a Comp spring made for this Comp Cam (the int and exh lobes are right out of the book) is not the right spring? More people have broken REV duals with this cam then the Comps.
"The G5X2 is fine for a daily driver, but you need the right springs to begin with."
And how much hands on experience do YOU have with this cam? I glad there are so many experts armed with keyboards, I thought I would try to give some real world, first hand experience on this subject but I can see there are far too many experts for me to help with this subject.
I have a 9 sec barrier to break, Later
Brian
I do not have the insight in the LS1 engine that some others do...but I do understand Basic Engine Physics... and I do Know where I want to go with it..... With My Hemi I had some expert help building it...did most of the work myself...but still had the pro tellin me what to get...on this one..I am on my own...back to the Springs statement...
It doesnt make one bit of difference what spring you pu in if they are not the right ones....I know that...but If you are breaking them...and a differnt one is recommended by LG...then is it possible you have the wrong springs...or Is it a comp cam with comp springs...being sold by LG??? Springs can break for a lot of reasons....but if you have the right ones they should hold just fine...If you do what is recommended...like getting the car hot before High revs..
I should have put a ? after my bad luck statement...because I have read no other braeking my stuff stories on this cam(and I am sick of reading the stories) I just wonder if MAybe it was just a weak spring...and not the cam's fault...
Lots of guys with bigger...not having any springs problems... like I saked here just a little bit ago....Did you get he kit recommended...or a comp cams "equivelant"...If it was a different brand of springs...then it is not the recommended springs....hence the breaking...I take it back if thats what the recommended springs are...and if so...Is LG calling a comp cams camshaft their own creation??? I dont want to hit anybody on this topic...but I know a lot of companys buy cams that they have designed for them...but some of them do try to play like they were grinding it down themselves...
Sorry to ramble....
sorry to rant...
sorry to **** off anybody....
I just want more people with experience in this cam....
and good luck on Hitting the 9's thatyou want...I hope you make it.
A lot of the misinformation given about these springs are what is listed in the Comp Cams catalog, in which most of the information is referenced to standard SBC setups which many of rarely go much beyond .500 lift. The LS1 is a different animal however. To say the 987's aren't any stronger than 918's is ridiculous. The comp duals are better springs than the REV's, the REV's are good for people who want to use dual springs but don't want to machine the spring pockets to accept a larger diameter Comp spring.
Just another opinion for ya!
There is not a single sponsor on this board that grinds cams in house. Most are lobe masters right out of someones catalog, mostly Comp Cams.
so I should stick with my x1 for my daily driver...with manley springs and titanium retainers...??? just wanted to know all that oter stuff so I could make an Informed decision...
Sound man has it right.
Now, here is the real story. We have sold 115 of the G5X-2 cams, and 1600 Rev springs. Yes, Sixteen Hundred springs. There have only been about 8 springs that have broken. That is why we use the double springs, so there is a margin of safety so you won't drop the valve. We don't recommend any other spring right now. We have used some 987 comp springs, with good luck, but we still lean toward the REV springs, exclusivly.
I just got back from a track day with the G5X-2, and I did 140 laps and I hit the revlimiter every time, at 6900rpms on the strait, each lap, with the rev springs. No issues.
Brent, you are running a spring that we do not recommend for this cam. You are reving it to 7000 rpms on a regular basis with springs that we do not recomend, and you are bad mouthing the G5X-2 cam because you broke a spring that we do not recommend??? Plus you only broke the dampener.
What would you expect with any spring doing what you say you are doing to them.
This is a great cam. If people will use what we recommend, and install them properly, ( ie take the old seals with the hats out) then there will be less problems. We also recommend that the springs go through one heat cycle before reving them up too high.
Valve Springs have been breaking for years. Long before there was a G5X-2 cam.
Brian quote>>"I talk to dozens of people a day, many are not going to post their bad luck with a sponsors parts, or the posts get deleted."<<<end quote
So you will do it for them??
And without knowledge of the facts.
You say that the comp springs are the best for a comp lobe. yet you then say that you broke your comp spring?? Plenty of other springs 918 for example have broken in years past. Did everyone stop using the T1 or B1 cam because the 918 springs had a bad batch??
We had an M6 car in the shop for tuning yesterday with our G5X-2 cam and TEA heads. IT only made 413rwhp after tuning, through the mufflers. We had to dump the exhaust to full open and only got 428rwhp, and 390rwtq with the TEA heads on it.
The customer asked me what was wrong, since we just took an M6 car off the dyno with our G5X-2 cam, with Absolute speed heads that made 451rwhp/415rwtq through the mufflers, and CamM had 447rwhp,414rwtq and Glen has 454rwhp 418rwtq CamM had Absolute speed heads, and Glen has LG Motorsports heads.
My customer asked why his car would not produce better numbers, The answer is that the TEA heads do not flow at high lift. That is the real reason that Brian/Brent only want to see 570 lift cams, so the lack of high lift flow from the tea heads won't show up.
If I were you, I would worry more about the low hp numbers on those TEA heads. It would be best to become an expert on porting the heads that you DO sell, before you try to become an expert on Cams that you DON"T sell.
Sorry to be so blunt.
LG
THe REV springs do not coil bind until over 625 lift. Springs are not a life time part.
they have a limit like everything else. Springs cost about the same as a set of brake pads.
People don't have any hangups changing brake pads, so why not Valve springs.
A proper heat cycle will stop most of the problems.
Lou G
Brian
Maybe you should buy some heads from someone else and you can break into the 9's.
My point exactly, hence the need for a Comp 987 or 978 spring wich IS a LARGER DIAMETER spring. Again, to say these aren't as strong as a 918 single spring with stock diameter is really ridiculous.
I'm just weary of springs from comp.
