370 build
Old Jul 18, 2008 | 12:00 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default 370 build
just picked up a 6.0l motor gonna build a 370. what size pistons and rods are you guys using. also looking to go turbo also so brands would help to. im gonna run 317 heads and a stock crank.
Old Jul 18, 2008 | 08:28 PM
BIG BAD BLACKSS's Avatar
I has a speed inc 370 I have diamond -15 CC pistons, Eagle rods with L19 bolts, and the stock crank. Not sure what bearings they used. Diamond makes the best piston for boost in my opinion. The rods are kinda the econo brand in my mind but they are proven peices many many times over. Speed inc took this same motor (with the regular rod bolts) to 995 RWHP and high 8s and drive the car everywhere. If thats not proof of a great motor for the $ I dont know what is.
Old Jul 18, 2008 | 10:24 PM
Tom@SpeedInc's Avatar
Is this a used block? We use Diamond and/or Wiseco pistons
Typical for a build like you're explaining we would use Diamond 11517 piston
can be found on our site here
http://www.speedinc.com/cont.cfm?cid=C0000758
Old Jul 19, 2008 | 12:18 AM
1320 killer's Avatar
Diamond pistons 4.030 and eagle rods 6.125
Old Jul 19, 2008 | 12:25 AM
smok'nZ's Avatar
MASS seller approved
you will want -20-30 for a turbo or supercharger
Old Jul 19, 2008 | 01:15 AM
LS1Tech Sponsor
yes its a used block
Old Jul 19, 2008 | 01:37 AM
In that case bore it .030"
Used blocks we normally deck them .010-.020 and use a 6.100" connecting rod with stock crankshaft, diamond pistons are stacked up to be -.010 out the deck ( at stock deck height). With using the shorter rod you end up at 0 deck after machine work.
