What heads with MS4 cam
What is the best heads to go with the MS4 cam? And also is there different stages to the heads that would make more hp with the ms4 cam? thanks guys
depends on your setup and if you want to flycut or not...somehow i'm running TEA TFS 215s milled to 59cc chambers with .095" intake and .090" exhaust valve clearance, really surprised me. if you're willing to spend the money, a higher end head will help you a lot in every aspect over budget heads. I haven't had mine dyno'd yet but it should be putting out 480+rwhp through M6 with fast 90 and all supporting mods...
I have a set of 243 ls2/ls6 heads for 450 shipped, they worked great with my MS4 and ported weiand
remember that cam loves to breath up top, I used to freight train my buddies camaro with the same mods only he had 241's with light porting and a ls1 intake with his ms4. on the street it was a difference of 5/6 cars by the 1320 not sure about actual times or trap speeds
