Where are the results of Thunders new Cam???
. Should be getting numbers soon though... I wonder how long my 918's will last
Anyone trying this cam with an A4? I wonder how extreme it would be.
I used to run a 320/320 in a '67 Firebird, but that was advertized duration, not at 0.050. That's still pretty big though; probably around 270* @50 thou.
I used to run a 320/320 in a '67 Firebird, but that was advertized duration, not at 0.050. That's still pretty big though; probably around 270* @50 thou. there are only 360 degrees on the whole shaft!!!
why bother closing the valves at all???
I believe this to hold some merit based on what MTI has seen in their testing. However, I do not yet have a clear understanding as to why this seems to be so.
Actually, there are 720 degrees because cam duration is measured in crankshaft angle, not cam angle. Note that the crank must make two complete rotations to turn the cam over once. If you were to degree that 320 advertised directly on a lathe, you would actually measure 160* @ 3 thou cam shaft angle. Does that make sense?
cutout open cutout closed
232/226 .595/.585 415rwhp 394rwtq 404rwhp/382rwtq
226/226 .585/.585 402rwhp 380rwtq 391rwhp/373rwtq
232/236 .595/.598 421rwhp 390rwtq 410rwhp/380rwtq
Cam 1 lsa 110 zero advance
Cam 2 lsa 114 3 degrees of advance
Cam 3 lsa 114 4 degrees of advance
The funny thing is the 226/226 cam felt faster and idled like stock, but the dyno showed my current heads did not like that cam. We even have a local guy name Jim who dyno'd over 405rwhp with the same 226 cam. I sold it to him. The kicker is his car is a A4 with a huge stall and I think he had 3.73's. Go figure. He does have longtubes though. I lost power everywhere compared to Cam #1 and Cam #3 with the 226 cam. Now I have to take into consideration that my car has not been OFFICIALLY tuned since the T1 cam I had in the car. The only thing Ed Wright did was decrease the timing because I was running some pretty high compression b4 my last engine decided to let go. I only did one pull on Cam #3 because my goal was 420rwhp with Stage I heads. I got it and I was happy. Would I see a huge increase if I decide to stay NA and go Stage II? Who knows.. I am still a little skeptical of some of the #'s I read. Until I see 440rwhp plus on one of my local dynos's from a H/C 346ci LS1/LS6 car.. I will continue reading and smiling.. Am I a little curious about Thunders new cam..? Hell yeah, but I am tired of tearing the car apart..
