lifter stuck in block. any ideas?
In what manner is it stuck? Did it gaul into the block somehow? Is it simply on the base circle of the cam where it is not easy to grab? Is it broken?
Usually, one can rotate the cam until the lifter is on the top of a lobe & then grab it w/ a magnet, your fingers, needle nosed pliers.
