How Important is CR.
Old Aug 26, 2003 | 04:58 PM
HumpinSS's Avatar
Default How Important is CR.
Going from 10.1:1 to 11:1. How much HP gains best and worst case senerio will you net?
Old Aug 26, 2003 | 05:43 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: How Important is CR.
It's said that every full point increase in compression is worth 3% additional HP.
Some cams work better with more compression.
Old Aug 26, 2003 | 05:55 PM
GeorgeC's Avatar
That's a pretty good jump, and should net a decent increase in HP... An 11:1 LS1 shouldn't have any problems on pump gas, so it's a worthwhile jump.
You get to a point of diminishing returns on CR though... What I mean is that you will gain much more going from 9:1 to 10:1, than you would by going 13:1 to 14:1...
Old Aug 27, 2003 | 02:45 PM
robertbartsch's Avatar
My heads are milled .055 and yield an approximate static compression of 11.4
I run 93 **** gas and do not have any knock, however I am running a tad rich. ...the knock verification has been performed on A-Tap..
