Oil pan leaking?
Old Aug 3, 2008 | 12:01 AM
NoTicketsPlease's Avatar
Default Oil pan leaking?
Do these pics of my oil pan look normal? They are of the same area but from different angles. Another bolt had a similar amount of oil but I couldnt get a good pic of it. I have not noticed any drops of oil after parking but I havent paid close attention. I did not tighten anything, should I?
Attached Thumbnails Oil pan leaking?-100_1299.jpg   Oil pan leaking?-100_1300.jpg
Old Aug 3, 2008 | 12:11 AM
djsanchez2's Avatar
If it is where the front cover or the rear cover come together with the block, the RTV seal has broken down. Don't think tightening the bolts will fix the issue.
Old Aug 3, 2008 | 12:46 AM
The first pic is from below the car of the front of the oil pan.
Old Aug 7, 2008 | 02:34 PM
Does this look like a serious problem or just something to keep an eye on?
Old Aug 7, 2008 | 03:40 PM
conan's Avatar
Keep an eye on it, take a piece of card board and set under the car to see just how much is leaking out at a time. The bottom of the timing cover shares the oil pan gasket. Maybe time to do a cam swap and fix your gaskets at the same time
