450hp H/C combo
Old Aug 6, 2008 | 09:15 PM
88ls1blazer's Avatar
I would do a livernois stage 2 head w/ stage 2 r cam, they consistently see 440 w/ 2/2 on an ls6 manifold on stock injectors... the 2-r should get you another 10 hp or so then the 2
I think they have a package that is about 2400 shipped that includes ARP bolts, MLS head gaskets, copper spray, plugs, cam, pushrods, and heads...
Old Aug 6, 2008 | 10:42 PM
DVS99TRANS's Avatar
Originally Posted by Striker
I have a couple questions myself.
-At around what rwhp do the injectors and the fuel pump need to be upgraded?
-Is an upgraded oil pump neccesary?
I am lookin for the same power levels as well.
Around 400+rwhp is where the stock injectors need to be upgraded for sure. The main goal is to keep the injector at or below 80% duty cycle, above that they will not spray fuel accurately. The oil pump is mainly if your going to spin higher with a big cam, but is good insurance anyways regardless. I should be hitting this power level here once I get my final tune, and have replaced both oil pump and injectors.
Old Aug 6, 2008 | 11:29 PM
that240guy's Avatar
Originally Posted by KENS WS6
I just spent 7000 dollars on stage3 head and cam at livernois. 92mm fast intake and t/b
42lbs injectors and fuel pump. I had it tuned and I have 440hp to the rear, so 2300 dollars GOOD LUCK.
Sounds like you are seriously down on power if you are only at 440 to the wheels. 425 hp can be achieved with cam only/full bolt on setups. If those stage 3 heads are only netting you an extra 15 hp, sounds like someone didn't do their homework on either the cam selection or the head headwork.
Old Aug 6, 2008 | 11:37 PM
lilbuddy1587's Avatar
Originally Posted by Paint_It_Black
Where I am purchasing my heads from, with the heads on my order sheet, I should be over 500rwhp easy through a 10 bolt on a forged 347. They are ported 243's, and the head/cam matching combo costs rougly $4200.
Originally Posted by KingSS
I spent 1700 bucks on my H/C setup and with a FAST 90 made 475. Looks like you are getting poked in the ***, especially for some LS6 heads. almost 3 grand extra for 25hp IF you even make the numbers you are claiming. You can buy a stroker motor for those kind of prices!
You spent only $1700 on a FAST 90/90 setup PLUS the heads/cam/misc. ?
What you dont understand is that peak power means nothing when you're soft down low. I'll bet his power under the curve will be much greater than yours with his peak just pulling away.
So for you to imply that you put down 475 "for only $1700 blah blah" and that he spent an extra "3 grand extra for 25 hp" is a ridiculous. A properly matched intake/heads/cam and other misc. necessities is straight up NASTY. 243's that were in the hands of Joe M. are going to simply be works of art and move plenty of air.
Old Aug 6, 2008 | 11:46 PM
socmguy's Avatar
Restricted User
sounds like MAYBE someone is making big power through and A4 or 9". Don't tell someone they didn't do their homework if you don't know their whole ******' setup! I don't know his setup either but I'm not going to criticize unless I've seen the entire drive train. Dyno numbers are bullshit anyway, track times are all that matter!!!
Old Aug 6, 2008 | 11:54 PM
DarkhorSe_SS's Avatar
Originally Posted by camnz06
I'll sell you my H/C setup... You'll need all boltons to get to this level...
Only has 2000 miles on it.
Hey bro pm a price you selling the h/c package for?? WHat are you upgrading to?
Old Aug 7, 2008 | 12:01 AM
KingSS's Avatar
That was 1700 before the FAST. I feel that the 5.3l heads with the MS3 is a very well matched combo. Heads with a smaller runner and smaller combustion chamber with a large cam. I have a very broad and useable powerband because of that. I daily drive my car still with 3.42's in the rear and i have no cam surge anywhere. Ill put my car against any other h/c street car out there, it makes plenty of power for a great price.
Old Aug 7, 2008 | 12:02 AM
LebaneseShowoff's Avatar
Do a Cam and SPRAY!!! MY cam swap alone cost me around $1,000 and that's without labor. So... either buy everything used or keep saving up. PRC 5.3 Stg 2.5 aren't too expensive used.
Old Aug 7, 2008 | 09:28 AM
I have read some of his prior posts is has a 12 bolt in it and a cam set up for spray IIRC... so good job knowing everything about his combo
Old Aug 7, 2008 | 11:18 AM
slt200mph's Avatar
The OP will have to spend more than $2K to get to 450 RWHP...
Old Aug 7, 2008 | 02:04 PM
Schantin's Avatar
I'm in the process of installing the "Va Speed" HC kit. New stock 243's ported w/ Dual valvesprings, pushrods, and a moderate Comp 111LSA cam. $1550. Add in gaskets, etc it'll be in the $2K range. W/ my upgraded fuel system, Lt's, GMMG, etc I should end out in the 420-450RWHP range w/ a 9" rear and 4.11 gears . So, it is possible...... but the key is the supporting mods.
Supporting mods: clutch - $500 to 12000 depending on brand, tune (unless you're doing it yourself), and save for the CheaTR cam, no HC package will work that great w/out headers, air intake, free-flowing exhaust, etc. It's all this supporting stuff that will drive the total price to the $4K+ range.
Old Aug 7, 2008 | 02:22 PM
  #32
slt200mph's Avatar
You can buy a cam kit for around $700 but I wonder what kind quality are the heads that you get for $850...
Old Aug 8, 2008 | 09:15 AM
  #33
a 111 LSA???
Old Aug 8, 2008 | 09:34 AM
  #34
ZMONSTER!'s Avatar
Could you post up your dyno sheet? Id love to see the power curve on that combo.
Old Aug 8, 2008 | 12:14 PM
  #35
Schantin's Avatar
New stock casting 243's that are hand ported with Patriot Dual springs and titanium retainers.
Originally Posted by 88ls1blazer
a 111 LSA???
Yes, Comp 228/232 .600/.601 111LSA. Installed straight up.
Old Aug 8, 2008 | 04:28 PM
  #36
slt200mph's Avatar
OK you've got $250 in the springs...what kind of ported heads do you get for other $600 ... Like I said I wonder about the quality meaning how well they perform and what kind of flow numbers they produce......hand porting is old school tech that is why CNC porting is used now days so that all the porting is duplicated identically.
Old Aug 8, 2008 | 09:21 PM
  #37
CNC doesn't always mean "quality". Hand porting may be "old school tech" but guess what? Some of the BEST in the business use that "old school tech".
Old Aug 9, 2008 | 12:04 AM
  #38
Schantin's Avatar
CNC is nothing more than a proven hand ported design that has been digitized and thus reproducable on a mass scale to cut production costs and let the general public enjoy the benefit of a well-ported head.
Sure I could have spent $2300-2800 on AFR's or TrickFlows, but the heads I got look great and they are 64cc 243 castings. I can spend that other $2K elsewhere now.
As for your doubts....It's cool. If I hadn't dealt w/ Va Speed before on other work (got a 9" rear center section assembled by them) then I might be skeptical too. So far their assembly/workmanship has been top notch.
Hell if nothing else I'll take her to the track and let the timeslips (not the flowbench) be the measure of performance once I get it assembled
Exactly.
Old Aug 9, 2008 | 01:53 PM
  #39
slt200mph's Avatar
I am very familar with old school tech since I am old school (45+ years of hot rodding) All of your prototype porting is done by hand till the right port shape is found that produces the flow that the head porter is seeking but then it is duplicated with a CNC program for ease of production..
Old Nov 11, 2008 | 09:29 PM
  #40
DGageSS's Avatar
^^^^^what he said!!
