what do you think of this setup
Old Aug 6, 2008 | 10:29 PM
1fastmofo's Avatar
Default what do you think of this setup
tsp 5.3 2.5s, torquer v3, 3400 yank, ls6 intake, is this a good cam selection? car will likely have nos later. 98 injectors. car is a 93 rx7 so my only option for headers because of the auto is mid lengths
Old Aug 7, 2008 | 12:45 AM
chevy2808's Avatar
G.t.f.o.
Old Aug 7, 2008 | 08:30 AM
outkast6991's Avatar
there are better choices out there
Old Aug 7, 2008 | 09:42 AM
1fastmofo's Avatar
gtfo? outcast what do you suggest?
from everything i have read the prc 2.5 stage 5.3 are a good back for your buck.
i already have the yank
ps rear end gear is 4.10
Old Aug 7, 2008 | 10:04 AM
5_02ls1's Avatar
theres a guy on a local forum i go to made 420/390 thru a stalled a4 with that same setup....then another guy made 430/399 with those heads and the smaller 228r cam.....
Old Aug 7, 2008 | 04:45 PM
the heads are fine for a budget setup from what i've seen, but i would be looking for either a custom grind similar to chris1313 or just have one of the cam gurus spec one out for your setup(pat g, predator). the cam choice and attention to the setup is going to make or break the combo. i wouldn't be as concerned with peak #'s as i would with power in the usable rpm range. just my opinion
Old Aug 8, 2008 | 06:58 PM
1fastmofo's Avatar
how do i get em to spec me out a cam?
Old Aug 8, 2008 | 08:07 PM
Dragkid1917's Avatar
bro that cam is absolutley 100% fine. BUT, if you look at the specs of the V.3 theres a huge intake lift. I dont know how well that will work with milling or anything, so you might wanto check that out. Theres cam's with more equal intake and exaust lift's witch i like more. Theres the Torquer v.2 which makes less power then the v.3 then theres the 233/239 which makes a bit more, then the magic stick 3, witch makes even a little bit more. I love my 233/239, but theres nothign "wrong" with the v.3
Old Aug 8, 2008 | 08:53 PM
s346k's Avatar
that setup looks good. with regard to intake lift and ptv...as explained many many times, the valve lift has very little to do with ptv, duration is more of a deciding factor. i would have patrickg custom spec you a cam, it's $25, but is worth every penny. i think you get it back when ordering a cam from thunder racing? run a search in the internal engine forum for "Patrick G".
Old Aug 10, 2008 | 08:30 AM
1fastmofo's Avatar
found folks talking about him but no posts by him...
Old Aug 10, 2008 | 10:14 AM
SOMbitch's Avatar
As light as you are MS3 with those heads would work well but I would PM Predator-Z or as mentioned Pat G and go custom. Here ya go. patrick@guerragroup.com Also search his thread on here The "recipie" to 500 rwhp with heads and cam. The most informative thread I have ever read.
Old Aug 14, 2008 | 08:44 AM
1fastmofo's Avatar
is there a keyword or something to get him to respond or do you pay him to respond to a pm? (patrick)
Old Aug 17, 2008 | 04:18 PM
1fastmofo's Avatar
what are my 98 injectors good up till hp wise?
Old Aug 17, 2008 | 05:55 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
LS1tech has a lot of guys who like to recommend cam gurus that often have very little actual LS1 cam development experience. We use ENGINE DYNO & CHASSIS DYNO experience to test our camshafts next to competitors camshafts & our own possible new camshafts. I'd be willing to bet we've installed 75+ different camshafts in engine dyno applications chasing power & torque gains.
If your wanting a custom cam TSP can definately help you with it. We've dyno tested all kinds of different applications & lobe options NOT JUST FROM COMP!
The torquer 3 camshaft does really well & makes power earlier than the MS series of camshafts. The Torquer 3 & PRC heads have proven to make 100rwhp gains by installing the package!
Look for dyno comparisons very shortly! We're testing PRC LS6 heads, PRC 5.3l heads, PRC new casting, and a few other companies cylinder heads...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 17, 2008 | 07:56 PM
redchevytruck's Avatar
Default ?
well i guss thats one way to go . . . .
Old Aug 17, 2008 | 08:58 PM
ZMONSTER!'s Avatar
Iwent with the 5.3's and a 224/228 114+2 and gained ~120 rwhp. Didnt have a baseline dyno pull but assuming stock Z's make ~300rwhp and after H/C Im at 425 on a dyno dynamics dyno.
I would think the OP's combo would be just fine
Old Aug 17, 2008 | 09:25 PM
67camaro's Avatar
Sounds like a good combo. Especially with your light weight and 4.10's.
your 98 injectors might cut it but 32-42 pounders are usually recommended with H/C setups.
Old Aug 24, 2008 | 02:15 PM
1fastmofo's Avatar
jason now you offer the ls6 2.5's so now i am thinking those. where can i get a flow chart?
