160 Thermo question
Old Aug 7, 2008 | 10:38 AM
th41427's Avatar
Default 160 Thermo question
I was wondering if i should change out my thermostat to prevent detenation with a 160 degree thermostat. I have Diamond pistons with -2cc valve releifs on scat h beam rods 6.125 length. The heads are TSP PRC stage 2.5 milled down to 59cc chambers. the Camshaft i have is TSP 233/239 on 112 LSA. the intake i am using is a standard ls6 intake. i was just wondering if this will help me or actually hurt me? thanks
Old Aug 7, 2008 | 10:39 AM
th41427's Avatar
the compression ration should be around 11.1:1
Old Aug 7, 2008 | 07:49 PM
smokeum99ta's Avatar
It wouldn't hurt to change it out. Just need your fans programmed to come on at a lower temp. to take advantage of it.
Old Aug 7, 2008 | 08:06 PM
JFM-jr's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/964058-160-t-stat-low.html
Old Aug 7, 2008 | 11:00 PM
jlrz28's Avatar
10 Second Fun Car
I think it was an easy mod that made the motor run cooler. It was one of the first mods I did to my car about 6 years ago and its still running strong with 134k. The car had 25k when I bought it. Just remember if your not reprogramming the fans then it wont be as good as it could be. It also depends on where you live, up north I might think twice about it but in the south, go for it.
Old Aug 7, 2008 | 11:24 PM
kill_machine85's Avatar
If you dont have one get a electric water pump(a race one) that is high flow and ditch the thermostat all together.
Old Aug 8, 2008 | 04:00 PM
2000Hawk's Avatar
When i tuned my car the tuner had played with my fans so i could add the 160* t-stat. I never thought it was going to make a difference, but recently i had to change out my water pump. I decided on getting a 160* t-stat as well, and what a difference. Not performance wise but by using a hand held scanner i can see the car is running alot cooler than before.
-Joel
Old Aug 8, 2008 | 05:58 PM
th41427's Avatar
Default thanks
Thanks for all the information. i live in the south so i believe it could do nothing but help. i didnt think about about playing with the fans to get the full effect. thanks again.
Old Aug 8, 2008 | 06:08 PM
BobDoLe's Avatar
in really hot temperatures, i was getting a little knock retard showing on a scanner. after i switched to the 160tstat, it seemed to help. the coolant temp reads under 180 on the freeway and when its hot outside, i can jump on the throttle without any knock retard showing up - for me, that was the biggest gain.
Old Aug 8, 2008 | 06:26 PM
01ssreda4's Avatar
i was running 230+ in traffic in 100* heat. i found out the factory fans come on at like 228 or some ****. i had my tuner turn mine on at 195 and it stays between there and 205* all the time now. all this was with a 160 thermostat.
Old Aug 9, 2008 | 06:37 PM
2000Hawk's Avatar
Same thing here, ever since installed the 160* my temp has never gotten anywhere near 230*.
-Joel
**I found the thread from when i changed out my water pump and swapped to the 160* t-stat. Prior to 160* i would see temps as high as 224*, and im sure on extremely hot south fl. days it would climb to 230*. The highest it ever got while driving around since the install has been 194*. Which is a nice drop from the usual 220*+ that i would see before changing it out.
Old Aug 9, 2008 | 08:09 PM
Viper's Avatar
After 8 years of a 160, I switched back to stock and programmed the fans for 200.
https://ls1tech.com/forums/showthrea...760&highlight=
