texas speed ?
Old Aug 7, 2008 | 08:02 PM
tboysen00's Avatar
Default texas speed ?
Ive read up but all i ever see is opinion and hp #s. I would like to see different 1/4 mile times between these two setups.
prc 5.3/ms3 vs. prc ls6/ms4 -with or without a fast setup. Just post if you have it or not along with 6-speed or auto.
Thank you, Troy
Old Aug 8, 2008 | 04:54 PM
tboysen00's Avatar
???????????? HEEEEEEEEEELLLLPPPPPPPPPPP haha
Old Aug 8, 2008 | 05:31 PM
b0pric01's Avatar
why 1/4 mile times? There are going to be so many more variables with traps/e.t.'s than with dyno numbers it will make a decision more difficult if you ask me.
Old Aug 9, 2008 | 02:48 AM
PREDATOR-Z's Avatar
That is not the right section for that.
Look in the ET sections, also in the fastest A3/4 and M6 sections.
This is an INTERNAL tech section.
Old Aug 9, 2008 | 06:35 PM
2000Hawk's Avatar
Thank you, Troy
As predator said you might get your answer in the ET threads. Also take into account that alot of variables can change what times people get. From altitude and temperature, to what bolts ons, rear end gears, weight. Also remember you will need gears to be able to use both cams to their full potential.
-Joel
Old Sep 26, 2008 | 10:14 PM
tboysen00's Avatar
yes I realize that but I figured people would post supporting mods.
