Quick ? on 241s
Old Aug 9, 2008 | 10:02 AM
Bizzles's Avatar
Default Quick ? on 241s
I have a set of 241s I'd like to put on my 2000. I guess my car was an early 00 engine b/c it has the 853s. My ? is do the late 00 LS1s have the same cam or did they switch it over to the smaller one that they used in 01-02??
THANKS GUYS!!!
Edit: Or a simpler question. If I put the 241s on the car will it work as good or better than the 853s with the stock 00 cam? I figured it would b/c the difference between the two is just the cast method?? or are the flow caracteristics so different that the 00 cam will actually loose performance over the stock 853s?
Old Aug 9, 2008 | 10:48 AM
ABQ99TA's Avatar
I think that they are so close it is not worth swaping unless the 241s are P&P.
Old Aug 9, 2008 | 10:50 AM
studderin's Avatar
^^ ya, unless some other resone, thouse stock casting arn't gona be that differnt in power.
buy my ported 241
Old Aug 9, 2008 | 11:24 AM
matt3383's Avatar
i have a late model 00 with 241 heads. I believe the cam never changed though. If your going to do some head swaping at least port the 241's.
Old Aug 9, 2008 | 04:58 PM
Bizzles's Avatar
Much abliged.
