first ls1 build, a few simple questions
Now before I install these pistons, where should the top oil scraper ring's gap be in relation to the big ring above it (the bottom of the two big rings)? Does it matter?
Thanks again guys I can't wait to install!!
Like this if you have valve reliefs.
Good tip on the valve reliefs too. My Wisecos DO have valve reliefs so I will make sure they will be put in properly. lol
There's a dot on the piston face that is the indicator for the front of the engine so now I have two references ha
I made sure the ring gaps were 180° apart, oil on the rings and piston skirt, Royal Purple Max Tuff on the bearings, rod cap sides matched the rod sides, the piston dot faced the front of the engine, 1,3,5,7 on driver's side and 2,4,6,8 on passenger, and that the ARP rod bolts were torqued to 45 ft lbs.
Before that I made sure the cylinders were cleaned thoroughly with 100% virgin lacquer thinner, and then coated with oil.
I know the engine is supposed to be really clean, but man it was tough to keep everything so clean. There was Max Tuff lube, moly lube, oil, lacquer thinner, and sweat all swirling around. I tried but I got moly lube all over the crank throw fins I think.
Anyway, you guys really helped me out installing them, so thanks again. Here are a few pics if you want to see:
http://zigzautonotes.googlepages.com/R0010181.jpg
http://zigzautonotes.googlepages.com/R0010186.jpg
http://zigzautonotes.googlepages.com/R0010188.jpg
http://zigzautonotes.googlepages.com/R0010187.jpg
Next up is the double roller timing chain (TSP) and the cam install.
Looking through the pics everything looks good. If you haven't already, a good thing we like to do is put a little RTV under the head of the side bolts in the main caps. Sometimes oil likes to seep out of those holes if you don't.
Kent
Got the UPS tracking number this morning for the Rollmaster timing chain. Should be here tomorrow. Camshaft/oil pump install will be perfect for this Labor Day weekend!
My double roller timing chain came in today so I ported my oil pump tonight:
http://zigzautonotes.googlepages.com...ump_PORTED.jpg
It's my first time porting ANYTHING, so please keep the laughter to a minimum! I did the best that I could with the dremel tool hitting the edges of the metal of the housing. Looks like it will flow better than stock though. After I was done porting, I removed the spring and let the housing soak in mineral spirits for about 10 minutes and then sprayed it with carb cleaner and wiped out all of the little bits that came from the porting. Looked pretty clean so I dried it up and torqued the bolts to 12 Nm.
All set for the camshaft/oil pump install this weekend. Just have to survive the rest of the work week now!
i tried another bolt in the same hole, SAME THING. I'm trying not to freak out. What do I do from here?
Sounds like you are going to need to learn how to re-tap holes. They're probably screwed up though so you may have to helicoil or use a keen-sert. I prefer keen-serts myself but they are expensive and you may not be able to use them in this situation. Helicoil is also a good method for repairing threads. Be careful because you will make little tiny metal chips and they will get everywhere if you aren't careful. Don't freak out you can fix this one too. Got the UPS tracking number this morning for the Rollmaster timing chain. Should be here tomorrow. Camshaft/oil pump install will be perfect for this Labor Day weekend!
Dude, degree the cam. Just in case. I've done many timing sets (LS2 type) that are usually off a couple degrees, Manleys's are dead on though. The number one rule in building engines is to assume everything is F'd up, not that everything is right. When you find something like that set of pistons where the "fwd->" marks are wrong, you'll be glad you checked! You're doing good so far, keep asking questions, keep sweating the details.
